Author Topic: clutch replacement/upgrade.  (Read 4090 times)
3seriesNut
« on: April 09, 2009, 10:04:11 PM »
whats a good upgrade/replacement clutch for a 318?  my pedal is letting out high,so im asuming that the clutch is going. i figured while i have it on the rack to do the exhaust i migth as well do the clutch,bushings,short shift kit and suspension too.
3seriesNut
« Reply #1 on: April 10, 2009, 11:18:39 PM »
i think ive decided on a centerforce dual friction kit.
mjnov
« Reply #2 on: April 14, 2009, 05:12:23 AM »
sounds good to me... as long as its not standard... cant really go wrong unless u have major engine mods. button type clutch plates are usually good but for daily driving can get annoying in traffic. they dont last as long either
3seriesNut
« Reply #3 on: April 14, 2009, 05:18:49 AM »
so ive been looking somemore and im stuck between a centerforce DF kit and a southbend TZ series or OFE series. choices choices. also can the stock dualmass fly be lightened any?
quinn11m20
« Reply #4 on: April 14, 2009, 06:51:28 AM »
I am looking into http://www.specclutch.com . Centerforce has one for our cars but is more expensive than spec. I am gonna try for a stage 2. But my mechanic has told me that He has replaced a few Dual mass Fly's to the aluminum one's. He is strongly against it because the M42 is balanced to that heavier fly. The customers have been back with idling problems and such. I plan to upgrade my clutch but not the fly.
3seriesNut
« Reply #5 on: April 14, 2009, 03:59:09 PM »
quinn,i totaly forgot about spec. ive got clutches from them before.
3seriesNut
« Reply #6 on: April 14, 2009, 07:47:03 PM »
after further inquiry the southbend clutches are cheaper than spec's.  im still on the fence. ive had good luck with centerforces in other cars ive owned.
1991 E30 M42
« Reply #7 on: April 14, 2009, 11:30:51 PM »
if your going to replace you clutch you might as well upgrade to an m20 flywheel, from what i understand Spec makes a nice clutch kit, Centerforce makes awesome clutches but on all the e30 applications they do not have the weights because of bell housing clearance issues, also Ireland Engineering sells clutches mad to their specs by (i think) Sachs
quinn11m20
« Reply #8 on: April 15, 2009, 06:32:58 AM »
Hey 3 series what is southbends email address? I have known about centerforce for many years but spec seamed like, for some reason, a better choice.
quinn11m20
« Reply #9 on: April 15, 2009, 06:33:42 AM »
1991 e3 m42  , you have a lightweight flywheel and performance clutch on your car. Do you have any idling problems and is the throttle response seriously a lot faster?
3seriesNut
« Reply #10 on: April 15, 2009, 08:11:44 AM »
3seriesNut
« Reply #11 on: April 15, 2009, 08:12:55 AM »
quinn,ive used centerforce and spec in cars before. i personaly like centerforce products. but i think this time im gonna try a southbend package. id still like to know if its possiable to machine some weight of a stock dual mass flywheel. ive got access to machine shop and someone thats a damn good machinist
16v of E30
« Reply #12 on: April 18, 2009, 11:00:21 AM »
get rid of that heavy ass flywheel.  i believe you get all the clutch parts for a 325i and a throwout bearing from a 320i.  you will notice a big difference
someone please corect me if im wrong.
1991 E30 M42
« Reply #13 on: April 18, 2009, 11:07:46 AM »
Quote from: quinn11m20;70125
The car idles a little rougher than stock, but that could also be due to cams, cam timing, ecu tune and my urethane engine mounts. Throttle response is greatly improved over stock.
