Author Topic: Starting trouble 318is  (Read 2051 times)
Tekals
« on: April 04, 2009, 10:21:45 PM »
Hi, I've been having some trouble starting my bimmer lately, it began by a simple no response when turning the key to start, like if i wasnt doing my "anti-theft security". It wasnt that bad at first, I just shorted the starter to make it turn a bit, go back inside the car and it would usually work.
At the moment, it got really worst, now when i try to start, it does way more than just not starting, It does a small noise and I lose everything electrical, meaning it shuts down everything and even if I turn switch on/off, i dont get back any lights in my dash.... To get it back i think i could unplug battery... but still it does the same each time...
At first i thought it was my starter, I took it out and tried it on a battery... worked fine... had little rust on them, i fixed this before putting it back hoping it could be a bad contact. WRONG, still does the same &?%/ again...
Do you guys have any suggestion? My bro thinks it could be a bad key switch, what you guys think?
renfield90
« Reply #1 on: April 06, 2009, 02:43:06 AM »
Check the battery...a dying battery or one with heavily corroded terminals has caused odd electrical problems for me in the past.
1991 318i
2001 Celica GT
Tekals
« Reply #2 on: April 13, 2009, 08:23:27 PM »
Yeah the battery was dead obviously, but the problem persists, this time i just get nothing when turning the key switch on starting position!
Took the starter out again, tried it again and again, looks to be alright but sometimes the contact looks hard to get to make it run. Although, i took out the starter switch with all the connections, couldn't find an electric scheme about it but we tested it in all positions and it looked to work fine. The "starting" position gives voltage on one of the wires but it seems that the signal doesnt reach the starter... where could it be dying?, it is a mess of wires under the dash!
Any scheme of the wire from the key switch to the starter? where it goes and all?
Any Idea of where the anti-theft thing could be?
