okey dokey, the new water pump is in there and I am putting everything back together. I decided to run some water through the radiator since its now the only old part of my coolant system. I took out the bleed screw and the cap, all the hoses were removed. When using a hose and putting water in where you fill, water came out from the drain plug. I closed the drain plug and water came out the bleed hole in the top. I covered the bleed hole with my finger and the water shot out of the fill hole. No water was coming out from the lower right hose hole. I then put my water hose in the lower right hole and water came out of the fill cap, drain plug and bleeder hole.
Is that all correct for the way it should flow? I thought that there would be water coming out the bottom right hole when I was putting water in the fill hole. But then it can go the opposite way so I think that may be fine?
kthanks
