Author Topic: Boiled in oil!  (Read 12671 times)
Choking Hazard
Boiled in oil!
« on: July 07, 2006, 09:15:16 PM »
:D
Oil, oil, whats yer favorite?  Not sweet venezualian crude but lubricatin' the m-42.  My favorite has been mobil-1 for this car, but I was told (:eek: ) that it is just another redistillation of dino fat.  Same feller uses amsoil hisself, so I'm giving it a try.  It has had a very curios side effect- occaisionally (NOT ALWAYS) as I accelerate through 3 k to 45 or 4700, there is a pleasent ~~Whirring~~ sound.  Reminds me of the ol' Nissan Z-car.  I guess it is valve train noise ??? but it doesn't sound like a problem.  Curious, yes.
Anyway, whats yer poison?  Mobil-1, castrol, etc.?  Do ya like it?  What viscosity?  I know all this has been covered- at least at bf.c- b/c I remember posting in a thread...
[SIGPIC][/SIGPIC]-Scott
sheepdog
  • Site Admin
Boiled in oil!
« Reply #1 on: July 07, 2006, 09:53:41 PM »
Check the links section of the site, it has a link to aninteresting study of Amsoil and Mobil 1.
Personally, I like Castrol Syntech (semi-syynthetic). It is just a bit cheaper than Mobil 1.
Oh, Mobil sued Castrol because when it came out they claimed it was full synthetic, some versions of Syntech still do. Since they all start from crude, what makes a full synthetic versus a semi., Mobil 1 lost. Not sure about appeals though.
An interesting thing on the Mobil1/Amsoil study, they found the most wear during the first 3000 miles after changing the oil. Phillips and Ford concluded the same thing, which is one reason companies are now telling you to go further between changes. Every 3000 mile sis doing more harm to your engine, and the environment, than good.
Right now I go about 8000 miles between changes.  Anything I run Mobil 1 in, I go at least 10.
thumper3ld
  • fathead ***
Boiled in oil!
« Reply #2 on: July 07, 2006, 10:51:37 PM »
Pentosin
-Founded in 1927, Deutsche Pentosin-Werke GmbH is a German-based developer and manufacturer of mineral oil based and synthetic fluids for the automotive industry. A leader in its field, Pentosin maintains its solid position through a combination of commitment to research and development and state-of-the-art manufacturing processes. Quality control and certification are integral to the Pentosin process. Pentosin products are original fill on all European brand cars.
Pentosynth Motor Oils are available as full or partial synthetic. These oils provide the highest performance, efficiency and fuel economy even under the most severe conditions.
silverblades181
Boiled in oil!
« Reply #3 on: July 07, 2006, 11:19:16 PM »
Castrol Synthec is not full synthetic? I thought it was...oh well, that's what I use in the 5W40 format. Says it meets the demands of BMW, Mercedes and Volkswagen and an experienced BMW Mechanic I know always puts 5W40 in the bimmers he services so I said why not. Anyway, I used it on the track and it lubricated my engine just fine. Might use the 5W50 next time though. I've heard the 20W50 is a bit too thick for our 4 cyls, what do you guys think?
E30 318is 1991 (Brilliantrot)
Bayerisch Motoren Werke
Boiled in oil!
« Reply #4 on: July 07, 2006, 11:27:39 PM »
Quote from: silverblades181
Well, it is a little heavy.  If you have a noisy vallveteain it will be a lot quieter than 10W-30.  I personally run 10-W40 in the hot seaon, 0-W40 in cold.  I am a Mobil 1 Full Synth person myself.
Oh and Choking Hazard, were you drunk when you posted?  That is the most jovial I have ever seen anyone over motor oil!  :D
bimma_318iS
Boiled in oil!
« Reply #5 on: July 08, 2006, 12:01:11 AM »
Quote from: bmwman91
I was thinking the same...
:D 1991 Alpineweis 318iS
;) 1999 Silver Integra LS
twinpop171
Boiled in oil!
« Reply #6 on: July 08, 2006, 08:58:57 AM »
He's still all geeked up from that high octane Canadian beer!!:D
Anyway back to the topic. I run Mobil 1 10W30 with no problems.
Dan.
Brillantrot 1991 318is
mgold
    • http://homepage.mac.com/mgold/BMW/PhotoAlbum42.html
Boiled in oil!
« Reply #7 on: July 08, 2006, 12:52:45 PM »
I run Castrol High Mileage 10w40 in my cabrio.  I've tried synthetics and didn't notice any difference.  I do run Amsoil in my tranny and diff and Mobil 1 in my PS resevoir.
sheepdog
  • Site Admin
Boiled in oil!
« Reply #8 on: July 08, 2006, 01:36:32 PM »
Some Syntech is, there are 2 versions. Trouble is defining what is full and what is partial.
My motor hated 20w50
Back in the day.
« Reply #9 on: July 08, 2006, 05:11:21 PM »
I was with a TransAm team that ran Lozano Brothers Porting small block Chevrolets. They tried about a dozen different oils. On a 310CI small block with a Holley 750 carburetor they said Mobil1 synthetic was good for 3 HP over everything else. This meant 633 instead of 630 HP. Not much but a couple more of those is......
silverblades181
Boiled in oil!
« Reply #10 on: July 08, 2006, 05:43:38 PM »
Quote from: sheepdog
I looked. The Castrol Synthec 5W40 and 5W50 says "full synthetic" on the bottle. (I work at a Canadian Tire) The others don't.
2002maniac
Boiled in oil!
« Reply #11 on: July 08, 2006, 06:23:44 PM »
I picked up 40 quarts of Mobil1 for $1.22 when they had it mismarked at target.  I use that.
:D
sheepdog
  • Site Admin
Boiled in oil!
« Reply #12 on: July 08, 2006, 06:51:12 PM »
They may have changed it since they won the lawsuit.
I will look at what is available here later this week when I go pick some up.
Deutschbag
Boiled in oil!
« Reply #13 on: July 08, 2006, 10:22:37 PM »
What weight does BMW recommend to use in the m42? And what brand of oil filter are you guys using? I was gonna go w/ bosch from Kragen, but if there's a better brand out there I'll gladly pick that up. Anything but FRAM.
mgold
Boiled in oil!
« Reply #14 on: July 08, 2006, 11:03:11 PM »
Quote from: Deutschbag
Not sure what BMW specifically recommended for the M42, I run 10w40 Castrol GTX High Mileage.  As for filter, don't buy Fram, Purolator or Bosch unless you're desperate.  I use Mann (OEM brand) and order about 6 at a time from Bavarian Autosport.
