Mechanical cam followers
Author Topic: Mechanical cam followers  (Read 6986 times)
dsm2002
« on: March 28, 2009, 11:34:22 PM »
Does this look like an option for our engines? Eurospec have a mechanical one piece cam follower set (4 valve 16 piece) for $160USD. Part no. is 027 198 309 HM14.5. It is 35mm in diameter with 14.5mm foot. This is close in size to the Catcams mechanical follower which has a 14.7mm foot.
nuvolarossa
« Reply #1 on: March 29, 2009, 02:00:33 AM »
here there are some 14.7mm lifters:
http://www.rosten-performance.com/pages/solid_lifters.html
A lot of VW tuners make them as they actually the same size. Check throught VW tuners websites.
I know nothing about fitting, no one documented that. It would be nice if someone wanted to be a guinea pig :)
dsm2002
« Reply #2 on: March 29, 2009, 07:06:26 PM »
48gm looks very nice :D. €17 ea however is a more expensive compared with $10USD for the eurospec. I wonder what the weight is for the eurospect followers.
« Last Edit: March 29, 2009, 07:09:57 PM by dsm2002 »
Deftones
« Reply #3 on: April 03, 2009, 06:49:08 PM »
have you thought about putting the S14 followers? here in italy we have lots of 320is which are normal e30 with a 2000cc S14 engine and it has stock mechanical followers so lots of people puts them in their M42...
http://blogs.yahoo.co.jp/luca318is
1992 318is e36
1990 318is e30
dsm2002
« Reply #4 on: April 14, 2009, 09:27:39 AM »
Received the cam followers today. At first glance, they look good and weight in at 40±g on the old kitchen scales. When I get time, I'll dig out the vernier clipers and check to measurements.
S14 followers are the wrong size.
Boyracer
    • http://www.jannousianen.net
« Reply #5 on: April 15, 2009, 02:15:11 AM »
Quote from: dsm2002;70048
Keep us updated! Were they really only 160 USD / 16 followers? :confused: :eek:
dsm2002
« Reply #6 on: April 15, 2009, 08:23:10 AM »
Quote from: Boyracer;70117
Yep. $160USD for 16 followers from 034 Motorsport.
Boyracer
« Reply #7 on: April 15, 2009, 08:46:45 AM »
Well that is a very decent price then! I sent them question to find out if they sell & ship to finland too :)
Boyracer
« Reply #8 on: April 15, 2009, 11:08:31 AM »
Eurospec just replied they are out of stock :(
http://www.034motorsport.com/product_info.php?products_id=629
Are similar but over twice as expensive :confused:
dsm2002
« Reply #9 on: May 06, 2009, 09:14:08 AM »
Quote from: Boyracer;70152
Jan, how did you go with these? Some research suggests that Renault 1.7litre F-Type engines may have the same size solid lifters. If you have not been able to get a set, maybe you'd like to explore this option to see if it correct.
Cheers
David
Boyracer
« Reply #10 on: May 07, 2009, 05:06:10 AM »
Hi,
I found company that will ship to finland and I have ordered a set :)
I ordered mine with 17,5 mm feet because I use stock valve lenghts. Even then the lash caps are going to be quite thick, around 4-5 mm with reground camshafts.
strypt
« Reply #11 on: May 07, 2009, 11:19:35 AM »
Quote from: Boyracer;71509
Hi,
Which company and how much where they?
Boyracer
« Reply #12 on: June 03, 2009, 04:02:18 AM »
Turned out that delivery time for 17,5 mm feet followers to finland would have been around august/september and I need the followers sooner so I had to cancel the order in the end :(
But if you need solid cam followers, I very seriously recommend these guys:
http://www.ngpracing.com/store/
Most friendly and helpful responses (hi Nate!) and no problems at all getting paypal payment refunded after the delivery time turned out to be too long for me :)
