You will definatly be up around 250hp on 10.5psi. my car makes 230whp on 10.5 and i didnt change anything other then pistons head gskt and head studs and standalone. im using the bosch green top injectors 42lbs they are getting close to the max though i think they will be good for 280whp maybe a bit more so i would definatly go for bigger then 42lbers if you want over 300whp.
I'm running stock 1.8L displacement and a DASC at 9psi. My injectors are Lucas 36 lb/hr and they are too big. My injector duty cycle at redline WOT are only about 65%, which I can read on the power commander III. I think I could go down to 32 lb/hr.Also stock FPR. 43psi idle, 50psi WOT.
Apparently they're a single pintle design where as the delphi ones are 3 pintles, leading for better fuel atomization.... i guess thats the only difference
