Hi all... this is an extract from my build thread just hoping someone can help!
On idle the engine hunts, when cold it's impossible to get idle unless the throttle stopper screw is wound in some way which means as it heats up the idle ends up being up at 1500 rpm. Setting it back down to around 900rpm once hot the wide band reading is close to pure oxygen which i'm taking a guess is the result of the ICV playing up. Once hot it doesn't stall but still hunts for idle.
She feels gutless under 6k rpm, feels like overfueling. We've only tried the wideband on stationary idle and when stationary reving which shows a lambda of 12 so overfuelling looks likely.
I've done quite a few modifications and a lot of work on the car including:
TB heater plate removal as per guide on this forum
Heater matrix bypass
Cold air box and filter
Custom exhaust (standard manifold, downpipe modified to include oval silencer, rear section modified to include round silencer, stainless DTM can)
Here's the full build thread:
http://m42club.com/forums/showthread.php?t=7825&page=1
