Author Topic: Timing question...  (Read 6590 times)
beemer1
Timing question...
« Reply #15 on: March 25, 2009, 12:39:18 PM »
Yeah that would have been a better idea but I needed the car finished ASAP as its my main mode of transportation.  I used sea foam in a spray bottle with an old tooth brush and some rags.  Let the sea foam soak and it came out pretty clean with some elbow grease.
I gotta say using mobil-1 for 10+ years sure as heck kept the motor clean.  No sludge build up:)
1991 E30 M42
Timing question...
« Reply #16 on: March 25, 2009, 01:44:07 PM »
btw a beemer is a motorcycle a bimmer is a car
beemer1
Timing question...
« Reply #17 on: March 25, 2009, 02:01:12 PM »
Quote from: 1991 E30 M42;68897
LOL, I hate when that happens!  When I was making my screen name I was in the middle of the whole timing chain debacle and needed advice quickly.  Now that you said it I do remember that, oops :o
1991 E30 M42
Timing question...
« Reply #18 on: March 26, 2009, 12:03:13 AM »
i have plenty of brain farts like that
bbarnumboy
Timing question...
« Reply #19 on: April 21, 2009, 10:51:39 PM »
where exactly is the tdc flywheel hole located at? i cannot find it and i am doing my head gasket right now.   also if i do not have the official tool what is the correct size of the rod to put in the hole? width wise. thanks guys.
nicknikolovski
Timing question...
« Reply #20 on: April 22, 2009, 03:12:40 AM »
Flywheel hole is right underneath starter motor and when the flywheel pin goes in, it will sit right up against the block. You can't miss it - just have a good look. If you haven't got the tool, use an 8mm drill bit.
What about the cams? Have you got the locking tool for the camshafts?
nicknikolovski
Timing question...
« Reply #21 on: April 22, 2009, 03:15:50 AM »
Also beemer1
Quote
Nick by the way are you Macedonian? If so dobar dan e hvala, thanks again!
Steve
Yes I am and Nema greshka
bbarnumboy
Timing question...
« Reply #22 on: April 22, 2009, 04:20:50 PM »
no cam tool but i made one thanks for the information  :-)
