Author Topic: New (Used) Differential install problems  (Read 1988 times)
John W
« on: March 07, 2009, 09:57:39 PM »
About a month and a half ago, my differential started making terrible noises. Finally got a used small case unit and put it in today. I went for a test drive. The 1/4 mile -- all at low speeds -- was fine. Then it started making noise. Then I remembered I forgot to fully tighten the rear diff mount bolt. I managed to get it home and loosened the four nuts that join the diff to the driveshaft. Then I tightened the diff mount nut/bolt. Then I retightened the four nuts to the drive shaft. The noise still persists. Any ideas? I think it may just be out of alignment somehow ... at least I hope that's all it is.
1991 BMW 318is SOLD :(
1976 BMW 2002 m20
2005 Ford Focus ZX-3
cabin
« Reply #1 on: March 08, 2009, 10:52:35 PM »
Probably a stupid question, but you did remember to put fresh fluid in it right?
Also, it would be pretty difficult to have it aligned incorrectly if the 4 bolts attaching it to the subframe are all in correctly.  They pretty much determine the alignment of the diff.
I would go back and check the torque on every bolt again, and make sure everything is where it needs to be and nothing is binding.
