Author Topic: Custom Intake Plenum  (Read 32235 times)
psyyambmw
« Reply #45 on: August 10, 2009, 12:14:03 AM »
Quote from: rob_e30;76269
Oh, that's a piece from Jon at 666 Fabrication.
http://www.666fabrication.com/
http://www.666fab.com/M42tubular.html This is exactly what I am asking for. ;)
Sadly, I don't think it gonna work with A/C street use in my tropical zone country + It gonna get stuck with my right-hand steering column though :(
« Last Edit: August 10, 2009, 01:36:11 AM by psyyambmw »
psyyambmw
« Reply #46 on: August 10, 2009, 01:32:16 AM »
Quote from: rob_e30;76323
We don't use the stock ECU.  We're running a custom Tec3R ECU from Vic Sias that features a MAP sensor.
This is awesome. :eek: Do you have some pic of it, Tec3R? What else you use for fine tune, ie, O2 wideband?
Again, thanx a lot,
George :rolleyes:
ps. do you actually spent over $3K for it ?
« Last Edit: August 10, 2009, 01:34:45 AM by psyyambmw »
rob_e30
« Reply #47 on: August 10, 2009, 01:39:16 PM »
Quote from: psyyambmw;76610
Again, thanx a lot,
George :rolleyes:
I don't have a pic of the install because it's up under the dash in the same location as the stock ECU.  It's a box with a bunch of wires.  We do have a wide band O2 sensor, as well as a knock sensor.  I don't recall exactly what we paid, but it's been a good deal for us so far as it gives all the engine control functionality we need and it's programmable.  Vic did a great job with the remote tuning and custom built our wiring harness.  Given what a race weekend or race engine can cost, it's a required expense.
e30guydownunder
« Reply #48 on: August 23, 2009, 07:25:34 AM »
have you guys had this thing dyno'd yet? what differences did it make to the power curve?
Also how is your knock sensor integrated to the ecu? does it need an external module as found in GM cars?
E30PQ
« Reply #49 on: August 23, 2009, 11:26:40 AM »
We plan on getting the thing on the dyno this week.
We use an aftermarket ECU which has the knock sensor integrated.  I think it's installed on the #3 cyl.
kevins08
« Reply #50 on: September 22, 2009, 01:43:19 PM »
dyno numbers? interested in buying before winter is up...
E30PQ
« Reply #51 on: September 23, 2009, 12:50:08 PM »
This project has been sidelined as we complete other projects on the car.
Initial dyno results did not produce the gains we expected.  We need to rework this part and that will most likely take place between race seasons.
1991 E30 M42
« Reply #52 on: September 23, 2009, 12:57:02 PM »
Are you boosted or n/a. If you are n/a you probably will not see much of a gain from a custom manifold unless you take your time and do the calculations for plenum volume and runner length otherwise you will more often then not loose power. Now if its boosted, it doesn't make as much of a difference because you are forcing air into the manifold.
E30PQ
« Reply #53 on: September 23, 2009, 01:29:43 PM »
This is the car we build the plenum for:
http://www.cardomain.com/ride/2980038
You could also see the car is the Sept '09 issue of Performance BMW
roundel318
« Reply #54 on: September 24, 2009, 11:33:37 AM »
everyone sure wants numbers :)
"Just tell me about the f$*@^!g golf shoes!!!"
Fear and loathing in Las Vegas
rob_e30
« Reply #55 on: September 25, 2009, 01:05:51 AM »
So we just got back from the dyno.  The new manifold made less power than expected but we just did an engine rebuild too so we wanted to eliminate other variables.  We reinstalled the original manifold and made less power still.  After some troubleshooting it looks like a bad injector so we were only running on 3 cylinders.  Once we get the problem resolved we'll be back to do more testing.  We don't expect to make a lot more power with the new manifold design, but we exoect to make it over a greater area.  Back to back testing on the 3 cylinders did seem to show that the new manifold made about 15+ more RWHP but given the other challenges I don't think it's a valid test.  Our peak RWHP when running right was well over 300 RWHP.
E30PQ
« Reply #56 on: September 25, 2009, 02:07:54 AM »
Stay tuned for more pictures of the new version (version 2.0) of the M42 Turbo D-Mod club racer.
A spoiler shot on the rollers tonight...
kevins08
« Reply #57 on: September 25, 2009, 01:33:23 PM »
sexy^
pm me when you have the numbers for the intake! id also be interested in knowing more about your setup if you wouldn't mind sharing details :D
persianbmw
« Reply #58 on: September 28, 2009, 05:51:33 AM »
What are the advantages of this over an obx manifold
kevins08
« Reply #59 on: September 28, 2009, 03:50:14 PM »
gtfo.
