Author Topic: Custom Intake Plenum  (Read 32310 times)
rob_e30
« Reply #30 on: July 27, 2009, 09:19:48 AM »
Thanks.  Its an M20 big bore throttle body, and the oil filler cap is from Pegasus but I think he went out of business.
psyyambmw
« Reply #31 on: July 30, 2009, 10:25:57 PM »
Quote from: rob_e30;75926
Thanks.  .................. and the oil filler cap is from Pegasus but I think he went out of business.
:( no wonder havn't seen it pita rare secret weapon again though. :p
by the way do you have a blueprint or some more pics vary angles of your turbo manifold or maybe can I buy 1 from you? and another 1 more thing what turbo you put on?
Many thanx
George
« Last Edit: July 30, 2009, 11:22:44 PM by psyyambmw »
« Reply #32 on: July 31, 2009, 01:55:40 PM »
Wow.  That's way beyond anything I'd have even daydreamed or sketched out on paper.  Nice job!
rob_e30
« Reply #33 on: July 31, 2009, 11:12:35 PM »
I can produce additional intakes.  They're $800 in aluminum and $1,000 USD in powdercoat including the runners (there is a core charge for the runners).  Depending on your displacement, I'd recommend a GT2860 or GT3071 Garrett turbo.
It will come with a blank throttle body flange (drill it to your match your throttle body) and I can customize the bosses/fittings for MAP, brake booster, air temp, and IAC if you would like.
« Last Edit: July 31, 2009, 11:14:40 PM by rob_e30 »
bwawuz02
« Reply #34 on: August 01, 2009, 09:48:58 AM »
any performance numbers on this unit yet?
kevins08
« Reply #35 on: August 01, 2009, 02:55:22 PM »
you said you were running a bored m20 throttle body correct? would you say this is a required or necessary upgrade, or just something you've done? would an m42 throttle body be sufficient?
xwill112x
« Reply #36 on: August 02, 2009, 12:08:23 PM »
that thing looks tits! good work!
Ich liebe meinen E30
laernu
« Reply #37 on: August 02, 2009, 12:23:00 PM »
how did you get rid of the MAF sensor without any problems D:? imma do the same thing but with a 75mm throttle body and custom weld my own Flange at the end of it lol...
psyyambmw
« Reply #38 on: August 02, 2009, 09:36:29 PM »
Quote from: rob_e30;76168
No Rob, I mean the exhaust one that i'm interesting though. :cool:
rob_e30
« Reply #39 on: August 03, 2009, 12:21:10 AM »
Quote from: psyyambmw;76265
Oh, that's a piece from Jon at 666 Fabrication.
http://www.666fabrication.com/
rob_e30
« Reply #40 on: August 04, 2009, 11:25:39 AM »
Quote from: laernu;76246
We don't use the stock ECU.  We're running a custom Tec3R ECU from Vic Sias that features a MAP sensor.
soadrules1989
« Reply #41 on: August 05, 2009, 10:47:48 PM »
hey with that turbo maniflod did you have to delete ac and power steering? is there any clearance issues?
rob_e30
« Reply #42 on: August 06, 2009, 12:44:15 AM »
Quote from: soadrules1989;76398
It is a purpose built race car now, so it's never had AC on it since we built the motor.  I think it would fit, but there may be problems with the AC lines, etc.  Check with Jon at 666 Fabrication.  The power steering is not a problem.
E30PQ
« Reply #43 on: August 06, 2009, 01:58:13 AM »
Quote from: kevins08;76207
We went with the big bore M20 tb for a couple of reasons.  One is that we didn't like the double butterfly of the M42 tb.  The other is that we had the big bore TB coming off my M20 and it turned out to be the right size tb for our turbo application.
E30PQ
« Reply #44 on: August 06, 2009, 02:03:53 AM »
Quote from: bwawuz02;76193
We should have performance number before the end of August.  Keep looking at this thread for an update.
We are finishing some body work this week (massaging the body kit from EuroStop).
The plan is to get the car painted within the next week.  After that we plan on scheduling some dyno time to tune the new intake.
