Author Topic: E30 318is front shocks  (Read 3264 times)
carlos318is
« on: March 02, 2009, 06:14:01 AM »
Can anyone tell me if the shock inserts from a E30 325 will fit a 318is as on the OEM they are the same part number. But I would of thought they would be a harder ride:confused:
« Last Edit: March 02, 2009, 10:45:22 AM by carlos318is »
carlos318is
« Reply #1 on: March 03, 2009, 03:39:05 AM »
Does anyone know the ansure to this:confused:
Bl0mgren
« Reply #2 on: March 03, 2009, 07:20:03 AM »
318is have 51mm struts just like 325, so the shock inserts should fit fine.
carlos318is
« Reply #3 on: March 03, 2009, 11:36:04 AM »
Thanks mate just what I needed to know
RED IS 91
« Reply #4 on: March 03, 2009, 06:06:36 PM »
Check out realoem.com to make sure . You should be able to compare the two struts .
