Author Topic: Help !!!!! water pump being stubborn.  (Read 2242 times)
justcool
« on: March 01, 2009, 04:24:37 PM »
Help me please! Removed the thermostat housing only to find no thermostat. No big issue. I will just buy another along with removing the mounds of silicone and a broken screw. But for the life of me I cannot understand why, when I took all the bolts off the water pump and used the push off holes ( just the name i call them) the bracketry around those holes broke. I am left a water pump that refuses to come out.
B318M42W
« Reply #1 on: March 01, 2009, 04:40:05 PM »
M90 Blown M42 :cool:
1991 E30 M42
« Reply #2 on: March 01, 2009, 04:41:16 PM »
get you a block of wood and a pry bar and try not to break the timing cover, it is a common problem
justcool
« Reply #3 on: March 01, 2009, 07:13:09 PM »
Quote from: B318M42W;67451
this page should help you a lot!
http://www.m42club.com/forums/showthread.php?t=7907&highlight=water+pump
Quote from: 1991 E30 M42;67452
Well the page was informative. However the pry bar and 2x4 that i used did the trick. The Pump out in three peices. All still together but broken. I know that i should suspect that pieces of metal are know in the cooling system. So my question is does the water hose method work or not
