Author Topic: getting oil in the spark plug tube???????  (Read 3620 times)
dwf08
« on: February 27, 2009, 02:36:49 PM »
i got a 91 318is its getting oil in the tube were the spark plug tube is it a valve cover gasket? or someone told me it had spark plug gaskets that go like a O ring or something can someone tell me a part # or where to get them or does it come with a valve cover gasket?
doitover
« Reply #1 on: February 27, 2009, 04:18:18 PM »
http://www.realoem.com  great resource for part numbers.
http://www.pelicanparts.com does sell the cam cover gasket with the spark plug gaskets if I remember correctly. If yours are leaking you might want to do all the gaskets around the cover bolts as well.
max123
« Reply #2 on: February 27, 2009, 04:18:25 PM »
I had the same problem - Its the valve cover gasket - easy fix.
P. Kennedy
« Reply #3 on: February 27, 2009, 10:21:32 PM »
+2.  Very common problem on the M42, and an easy fix.
Selfish
« Reply #4 on: March 01, 2009, 02:01:31 AM »
like everybody said, is not hard to fix. pelicanparts.com part # 11-12-1-721-876-M30
comes with the o-rings that go in the middle, 2 of them if I'm not wrong
JP 91iS
« Reply #5 on: March 01, 2009, 12:41:22 PM »
Quote from: Selfish;67407
4 rings - one for each spark plug. one is a lollipop shape to go around the bolt that is near (cyl 2).
-JP
Project M42: generating funds
batsbats
« Reply #6 on: March 06, 2009, 11:05:51 AM »
+111111 to everyone's comments.
Just be careful when torquing down the valve cover bolts.  They do not require much force to strip the holes.
renfield90
« Reply #7 on: March 11, 2009, 12:44:32 PM »
Quote from: batsbats;67805
Would you happen to know the torque specs? I'm probably going to be attempting this myself soon. My mechanic wants around 2 grand to do it...pulling the head should be fairly simple, right? I haven't done anything like this before.
1991 318i
2001 Celica GT
doitover
« Reply #8 on: March 11, 2009, 02:28:01 PM »
It is the valve cover gaskets right, not the head gasket? The valve cover bolts are 10 Nm. Two grand would have to be the head gasket.
renfield90
« Reply #9 on: March 11, 2009, 11:42:54 PM »
Yes, head gaskets. Honestly, the engine could really benefit from getting ALL gaskets replaced, but that's beyond the abilities of myself or my checkbook. I also don't feel like dropping in 3-4 times the car's value *just* to make it stop leaking oil. :rolleyes:
It's going to be my fun weekend/autocross/track car anyway, with its age and lack of care by the previous owner I'm not sure how long it's going to last.
1991 318i
2001 Celica GT
dwf08
« Reply #10 on: March 15, 2009, 06:27:58 PM »
got it
dwf08
« Reply #11 on: March 15, 2009, 06:28:28 PM »
thanks
