Author Topic: easy question...  (Read 3394 times)
B318M42W
easy question...
« on: February 26, 2009, 10:35:10 AM »
is there a coolant drain plug on the block side of the engine? if so, where is it?? and if there is, how do you fill up the block after?
thanks
M90 Blown M42 :cool:
doitover
easy question...
« Reply #1 on: February 26, 2009, 12:32:22 PM »
There is one near the back on the header side. I have read they are very difficult to remove. I didn't try, I've never really believed in the need to drain all the fluid.
JP 91iS
easy question...
« Reply #2 on: February 26, 2009, 04:12:04 PM »
Not hard to remove, at least in my experience.  Seems worth it to drain if you'll have the system open so you can do a full flush.  Its a 19mm (IIRC) below the exhaust manifold. And I think its torqued to 25Nm. And you just refill the same way as normal, through the radiator.
-JP
Project M42: generating funds
B318M42W
easy question...
« Reply #3 on: February 26, 2009, 04:31:00 PM »
thanks, working on the planning of the chain job, including new water pump..
