Author Topic: DISA+turbo in M43  (Read 14481 times)
woytek13
DISA+turbo in M43
« on: February 21, 2009, 04:21:58 AM »
Hello, :D
i've got some problems. I'm turbochargeing my M43B16 engine and i'm finishing almost but i don't know what should I do with DISA. Can it work properly with boost? No one helped me in Poland, all answers were: remove it. But I don't know can I.  :confused:
When I finish my project I an describe it here. It is low budget with some strange and original solutions.
Here is link for topic on local forum. I will rewrite it for you on english soon.
Thanks for help:)
wojtek
OT; sory for my english :o
haledj
DISA+turbo in M43
« Reply #1 on: February 22, 2009, 02:27:53 AM »
I would use the e30 intake manifold and leave the Disa disconnected.
Edit, Nevermind I don't know anything about the m43.
woytek13
DISA+turbo in M43
« Reply #2 on: February 22, 2009, 03:55:00 AM »
But does the M42 in e36 have DISA too? I think it has so thats why i am asking here. I saw a few turbocharged e36 I i thought somone could know that.
I forgot about link:
http://bmw3er.pl/viewtopic.php?t=3286
« Last Edit: February 22, 2009, 04:05:40 AM by woytek13 »
woytek13
DISA+turbo in M43
« Reply #3 on: February 24, 2009, 08:18:47 AM »
No one knows??
I gave you wrong link, sorry ;)
Here's good one : http://motolublin.pl/viewtopic.php?t=955&start=15&sid=fe77bf7d574f26b298952dd2179612b7
HaNasich
  • OO==00==OO
    • http://www.bangbros.com
DISA+turbo in M43
« Reply #4 on: February 26, 2009, 04:03:13 AM »
just disconnect the DISA and dont use it.
i have an 1995 M42 in my E30, used with E36 intake mani.
DISA is off, using the shorter wider route of the intake mani. always.
works like charm.
Ron.
WowMom
BTRA!
ludiagsm
DISA+turbo in M43
« Reply #5 on: February 26, 2009, 04:05:14 AM »
here is a friend of mine m42 turbo
    http://www.performance-bg.org/forum/viewtopic.php?p=34636#34636
disa must be removed  and you must use four extraijectors whit yours two maybe it will works but you will have hi fuel consuption and bad afr-s i tryed that it works but it was no good.
« Last Edit: February 26, 2009, 04:07:35 AM by ludiagsm »
woytek13
DISA+turbo in M43
« Reply #6 on: February 26, 2009, 04:27:21 AM »
Quote
must be removed
that's not good :/ Here I can see removed also all top of the manifold. I'll have to change all cooling pipes, pressure, and relocate throttle body. It is a lot of changes. If I just disconnect pressure pipes which are controlling DISA (like HaNasich said), does it work then? Manually removeing will be the best solution. I know that now, but I need easier way.
ludiagsm
DISA+turbo in M43
« Reply #7 on: February 26, 2009, 05:40:35 AM »
Quote from: woytek13;67259
an another friend of mine broke his engine becouse of disa some parts from  disa mechanism droped down to the valves .
woytek13
DISA+turbo in M43
« Reply #8 on: February 26, 2009, 12:17:48 PM »
Holy crap, now I know that some modifications can't be avoided. But i had nextsolution in my mind, manifold form M40 can be probably adapted to my M43 engine. Maybe I'll have less complications going that way? And it is also easy and cheaper to buy for me
woytek13
DISA+turbo in M43
« Reply #9 on: February 27, 2009, 08:53:34 AM »
Ok, today I've removed this rotating flap inside manifold. Do I have to remove all controlls of DISA (pipes, connectors, etc)? Or I can leave it like they are now?
m44power
DISA+turbo in M43
« Reply #10 on: February 27, 2009, 02:51:27 PM »
in metalic disa open the side cover remove the buterfly leave tha axle and you are ready (or leave it like that)
in plastic one brake the plastic butterfly and cut the axle that moves the butterfly a lot of people do that here in greece dont desconnect it otherwise you gone run in save mode map
sorry for my english...
woytek13
DISA+turbo in M43
« Reply #11 on: February 27, 2009, 03:05:44 PM »
I understand, thanks for that info. I can finish my project now :)
But do I have to plug on that thing? It was plugged to throttle body, and it goes to this:
« Last Edit: February 27, 2009, 03:07:52 PM by woytek13 »
bearsbmw
DISA+turbo in M43
« Reply #12 on: February 27, 2009, 03:25:01 PM »
Quote from: m44power;67329
you only run in safe mode if your obd2 or m44 when unpluging the DISA
« Last Edit: February 27, 2009, 03:27:05 PM by bearsbmw »
