DISCUSSION
Engine + Driveline
Has anyone used an M40 flywheel before?
Topic: Has anyone used an M40 flywheel before? (Read 2600 times)
redhead
February 20, 2009, 09:29:47 PM »
What clutch, TOB, starter, etc... do you use ?
colin86325
Hero Member
-Receive: 15
February 20, 2009, 10:54:05 PM »
I used the euro M42 single mass flywheel, which is the same part# as the M40. All you need is the clutch kit and flywheel bolts for the single mass flywheel.
Just use your stock M42 starter.
redhead
February 21, 2009, 12:32:10 AM »
So neither the M20 or M42 dual mass clutch kits will work with the M40(single mass M42) flywheel, correct?
colin86325
Hero Member
-Receive: 15
February 23, 2009, 03:10:21 PM »
As far as i know that is correct.
DISCUSSION
Engine + Driveline
