Good question. The lower timing case changed in 9/1993, which is also when the deflection rail was introduced.
The deflection rail mounts with 2 bolts, but the E30 idler sprocket mounts with only one bolt.
It's possible that the updated lower timing case introduces a new hole for the second bolt, but I can't say for sure.
