Recently Got a 1991 318is not to long ago.
The car runs well, and drives well ONLY when FULLY warmed up.
PO said the ICV could be bad, but I took it to a shop, and they said all need to do is clean the ICV (regarding the ICV problem). So I cleaned it iwth some brake clean shook it up and repeated.
Symptoms.
Car starts fine, and idles a little rough, with some minor surging, not noticable by RPM, only by ear.
If I put it in gear and start to drive before the heat needle is smack dab in the middle. It will rev up to about 2.5, and Bog down with my foot is on the gas. If I take my foot up, and try again it will rev up a bit more, then bog down again. sometimes it will bog down, and get spurts in and out of normal driving conditions.
Goes away once warm.
I also found out that the PO had deleted the Heater plate, not sure what else he has done,
but he said it could use a dinan chip, and yet the car will willfully rev to about 7000. seems like it does not have a limiter, or there may be a chip in the car already.
could this affect the car when it is warm with milage etc...?
Clean air filter P.s.
2002 guy that found an E30 as a daily
I dont know much about e30's but I have searched a bunch.
Thanks
