Author Topic: m47 Main cap  (Read 3587 times)
speedy8ty7
m47 Main cap
« on: February 06, 2009, 01:55:14 PM »
i was doing a little research on the m42 and read about the 180* thrust bearing. i was wondering if a m47 Main cap would work with the m42 block therefore getting a 360* thrust bearing
any help would be greatly appreciated.
cecotto
    • http://www.cecotto.dk
m47 Main cap
« Reply #1 on: February 06, 2009, 02:37:23 PM »
never mix and match caps like that.
They are linebored/honed together with the block. And as such unique to both the block and placement in the block.
If you read my buildup thread, i supplyed numbers on the bearings to use. Those will provide true 360 degrees of thrust bearing.
Steffen Otto Jensen
E30 318is
E30 M3
peerless
m47 Main cap
« Reply #2 on: February 06, 2009, 05:29:40 PM »
You can also have your original M42 main caps machined by Metric Mechanic to accept the early M20 bearings. You get the 360* thrust bearing AND 360* oiling grooves.
It cost about $125 to have the caps done through MM. I have had them do 2 sets for both my rebuilds. I am sure you could find a competent machinist locally to do the same, probably be about the same price.
Oh ya, also you can go with different main caps from a different engine, BUT you will have to have the block line bored and honed. Thats about a $150-$200 operation. And no, I do not know if the M47 caps would work, not familiar with that engine.
Robert
www.e30motorwerks.com
(714) 398-8405
speedy8ty7
m47 Main cap
« Reply #3 on: February 06, 2009, 06:22:59 PM »
Thanks for the help i think ive got the info i need
forrer13
m47 Main cap
« Reply #4 on: November 06, 2009, 10:14:51 AM »
I am trying to build 1 running engine out of 2 junk engines and am wondering if I can use the crank and main bearings out of block A (the bearing and crank surfaces look good) and put them into block B using the pistons from block B and new con rod bearings?
kowalski
  • El\' Duder
m47 Main cap
« Reply #5 on: November 09, 2009, 06:15:50 PM »
Quote from: cecotto;66021
you could get the block line-bored again. I've done this to swap caps on other motors, so I don't see this being a problem.
« Last Edit: November 09, 2009, 06:17:56 PM by kowalski »
Sale:
Fore Sale Thread
kowalski
  • El\' Duder
m47 Main cap
« Reply #6 on: November 09, 2009, 06:19:04 PM »
Quote from: forrer13;80994
you want to swap used main bearings from one block to another? they're not that expensive man....
Sale:
Fore Sale Thread
bwawuz02
m47 Main cap
« Reply #7 on: November 10, 2009, 10:52:59 PM »
So i misplaced the main bearing caps during disassembly, is there anyway to get them back in the right spot without having them line bored again?
are the markings on them helpful like the camshaft bearing caps?
