Timing chain job done. All new guides, chain, crank sprocket, water pump seal, front main seal, gaskets, etc.
Advanced the intake cam 2 degrees, retarded the exhaust 1 degree.
Fan and shroud removed.
Oil change done.
Green coolant removed and replaced the Saab blue coolant (VW G11 equal) .
New NGK plugs and Magnecor wires done.
New stock tail lights done.
Pulling the carpet out tomorrow for some pressure washer love.
Pulled the seats today and making brackets for the Jamex seats tomorrow.
Installed my 1992 Momo wheel today on the new hub which fixed several problems (broken wheel lock and turn signal cancel now fixed). Used a 1992 Benetton F1 horn button.
Ordered a CSB to replace the totally destroyed one that was in there. Replaced the trans crossmember and tranny mounts.
Ordered E28 engine mounts.
Ordered some late style coil packs so my new Magnecors might go up for sale.
Color matched the Kamei eyebrows to the car
Lamin-X ordered.
Tomorrow I'm going to start measuring for a rollbar which will tie into a rear shock tower/diff mount brace.
Still waiting on my control arms, wheel adapters and Weitec kit. Probably go order tires this week. Going to the American Lemans Series this weekend. So stoked.
