Author Topic: Removing crankshaft bolt.  (Read 3832 times)
BoostedEverything
« on: February 01, 2009, 03:24:28 PM »
Removing crankshaft bolt. The 22mm one... I'm using a wrench and about 3feet of 318is exhaust as a breaker bar, but it will hold there until i flip the engine block. I've soaked it with PBlaster to no avail... anyone have any tips? I have the bare block with just pistons and crank in it, sitting out of the car. It's getting a little annoying! I'm just trying to get the pistons and rods out but the crank is in the way, so I need to pull it.
Daily Driver: E34 BMW M5 Turbo 500WHP/500WTQ+ ~3500#
Other Beater: 92 DA Integra LS-Turbo 300whp/280wtq ~2100#
Winter Beater: 96 Neon ATX Sedan 100whp ~2000#
Project:[/
« Reply #1 on: February 01, 2009, 03:50:29 PM »
BoostedEverything
« Reply #2 on: February 01, 2009, 11:32:33 PM »
I jammed a bar between a few flywheel bolts and the block so the crank is not spinning, but the damn nut is definitely not coming off. I've only had to break the crankshaft nut off cars 2x before in my life, and both of those were battles but much easier than this. Is it normally threaded? Lefty-loosey? I'm at my wit's end lol.
Project:[/
nomad
« Reply #3 on: February 02, 2009, 12:14:21 AM »
Impact wrench is your friend.
Buy one from the local sears, use it once and return it if you "don't like it".
SoCal, 318is: IT RUNS AGAIN!
nicknikolovski
« Reply #4 on: February 02, 2009, 03:41:07 AM »
Come on, you can get it. Place an 8mm drill bit or flywheel lock pin in the lock pin hole just under the starter motor. Then use a big breaker bar - 1/2" and 22mm socket. Don't use piping its useless, it just slips.
txleadfoot
    • Google Profile
« Reply #5 on: February 02, 2009, 09:33:14 AM »
is your engine on a stand?  If so, the flywheel lock pin idea won't work.  I'd recommend a flywheel lock that bolts to the backside of the block.  I don't have one so I turned the block upside down, wedged a 2x4 inside the crankcase between the block and crankshaft, then used my jack handle as an extension on the 1/2" breaker bar.
nicknikolovski
« Reply #6 on: February 03, 2009, 02:54:23 AM »
The flywheel pin will work. Thats the point of it - to prevent the crank from turning hence if the crank does not turn you can loosen the bolt.
nicknikolovski
« Reply #7 on: February 03, 2009, 02:55:38 AM »
Also have you tried the starter motor trick.
txleadfoot
    • Google Profile
Duh
« Reply #8 on: February 03, 2009, 09:33:34 AM »
Ya, in my mind I was picturing the flywheel off.  Then for my comment it's magically back on.  Double duh!
Quote from: nicknikolovski;65839
