Author Topic: M42 engine max speed problem  (Read 3507 times)
scmooncake
« on: January 30, 2009, 09:49:45 AM »
Dear brother,
My car is 95 E36 M42 318IS AT. My engine can`t run above ~4500rpm...in either P,N and D shift. Is it had any prossible cases? I had already check the fault code (only 72 speed sensor problem). Many thanks for your kindly help!
roundel318
« Reply #1 on: February 04, 2009, 03:05:44 PM »
What happens to it above?
Does it cut like it's hitting redline / fuel cutoff?
xwill112x
« Reply #2 on: February 04, 2009, 05:45:24 PM »
its prob a 325 gauge. they act like there redlineing at 4500, but there really at 6500...when put on a m42
your tach is probly just off a bit.
Ich liebe meinen E30
Boosted E30
« Reply #3 on: February 04, 2009, 10:33:32 PM »
you need either a crankshaft sensor or theres probably an eninge speed sensor for the computer. mostlikly mounted on or around the transmision bell housing.
nicknikolovski
« Reply #4 on: February 05, 2009, 02:08:36 AM »
You can find one at Pelican Parts for $50.00.
scmooncake
« Reply #5 on: February 05, 2009, 10:11:48 AM »
It cut like it's hitting redline / fuel cutoff, anyway thanks to all of your kindly advise. i will check those possible cases !
roundel318
« Reply #6 on: February 05, 2009, 10:18:25 PM »
I have had this issue with my car.
Replacing the Crankshaft position sensor and reseating the ECU connector solved it.
scmooncake
« Reply #7 on: February 06, 2009, 12:16:19 PM »
Dear roundel318
Thanks for your helpful info!!
Is it had any fault code?
BoostedEverything
« Reply #8 on: February 06, 2009, 01:55:27 PM »
If you need a replacement sensor, shoot me a PM. I just stripped a running motor.
Daily Driver: E34 BMW M5 Turbo 500WHP/500WTQ+ ~3500#
Other Beater: 92 DA Integra LS-Turbo 300whp/280wtq ~2100#
Winter Beater: 96 Neon ATX Sedan 100whp ~2000#
Project:[/
roundel318
« Reply #9 on: February 07, 2009, 09:50:56 AM »
That was part of the pain, I got no fault codes from it.
xwill112x
« Reply #10 on: February 08, 2009, 10:27:59 AM »
i think qiuene30 may be depressed....
sad sad story
colin86325
« Reply #11 on: February 10, 2009, 10:04:52 AM »
I had a problem like that on my M3.  Somebody had swapped a 6-cylinder engine cluster into the car, so the rpms read 2/3 of the actual value.
