I can confirm that this trick isn't working on my car. Couldn't it be faulty temperature sensor? Sending wrong signal to the ECU and the ECU thinks the engine is cold and flooding it? Also my car is a bit thirsty. More than it should be, the gauge ks going down too quickly and I won't do many miles for the amount of petrol I'm getting.
Anyway, I wanted to check the sensor today, but couldn't stick the probes into pins to see what's the story between the ECU and the sensor.
And the fuel pump died today. Strange. I stopped at motor factors for something and couldn't start the engine. I was thinking it will start after a while like always but no. Spark plugs dry, then there wasn't anything coming out of the filter when I removed the hose and put on a longer one that I put into a canyster.
this is how I got home today
