Author Topic: front wheel hub bearing  (Read 2611 times)
mark_i
« on: January 20, 2009, 02:18:36 AM »
Hi All
Can wheel hub bearings be re-used...?
I removed a front hub bearing from an e30 breakers without much force, installed on my 318is and the bearing noise is worse.
Hub spins freely without resistance or excess movement.
Do the bearing races get wrecked when the bearing is pulled off the axle because I noticed the two bearing halves had separtaed by 2mm?
Thanks, Mark
twright
« Reply #1 on: January 20, 2009, 06:47:07 AM »
I have reused the whole hub from a 318is.  I don't know if you can separate the bearings from the hub and then reuse them.
