Author Topic: Removed aftermarket radio now turn signals don't work  (Read 3352 times)
cadence
« on: January 19, 2009, 03:56:06 PM »
I just bought a 91 318is and i am in the process of removing a lot of bad taste things done by the previous owner.  i removed the cd player today as it worked intermittenly. I have nothing plugged in to the cd player plug, and now my turn signals don't work.  They were working right before i uninstalled the cd player.  could there be any wires involved with the cd player wiring that would cause them to stop working?
Royalratch
« Reply #1 on: January 19, 2009, 05:49:17 PM »
A lot of cowboy installers, instead of using a proper loom from the supply panel behind the glovebox, will wire into the hazard light switch or other stuff related to that circuit. When you removed the stereo did you remove it's wiring?
That's probably what's causing it.
cadence
« Reply #2 on: January 20, 2009, 11:50:39 AM »
Quote from: Royalratch;64993
sounds about right the PO was deffinately a cowboy.  it was hard wired into some wiring directly behind the radio.  are there wiring diagrams online?
« Last Edit: January 20, 2009, 11:59:16 AM by cadence »
cadence
« Reply #4 on: January 22, 2009, 03:25:35 PM »
Quote from: ak96ss;65049
http://m42club.com/forums/showthread.php?t=7748
thank you very much i guess i shoulda searched electrical manual instead of repair manual.
cadence
« Reply #5 on: January 30, 2009, 10:05:53 AM »
just to give anyone an update.  i was looking around and found that the Emergency flasher plug was half unplugged i guess when i took out the old radio i hit it somehow.  once the plug was plugged all the way in everything worked
