Author Topic: another budget turbo build...bottom mount  (Read 90450 times)
tglaze
    • http://www.dynotechonline.com
dynotech motorsports budget turbo build
« Reply #30 on: January 22, 2009, 11:25:09 AM »
Quote from: AcSchnitzer318is;65174
glaze, where'd u get the MS plug n play from?  You custom make it or is that widely available now?  I knew it could be custom made... but that one looks pretty damn good.
I build the megasquirts here..
heres another item on the car i forgot to mention.  we do the m20 lightenbed flywheels and swap the ring gears so they are PnP for m42 as well. threw this in with a stage 3 m20 clutch.
might tack on a few extra bucks to the build for this setup as well.
Todd Glazier
call 760-726-7111 for parts
tglaze
« Reply #31 on: January 22, 2009, 11:44:43 AM »
oh ya, and that elbow deal..I was able to cram a 2.5" on the stock AFM but it wasnt easy. 3.0" however is wayy to big so you kinda gotta make the 2,5 work.  just spit on it and use a thin little flathead screwdriver or something to sorta work it on as you push down.  two peaple will make it easier too.
so, the official size to go from the stock AFM to the TB is 3.5" - 2.5".  now the other question at hand is whether to use a 90^ or a 45^ because the angle is somewhere in-between.  I would say its closer to a 90 if anything.  I imagine most of you guys running the stock afm dont still have it mounted in the origional location so that probably doesnt matter anyways.
there is one more issue at hand.  the hose that comes off the factory elbow that goes to the idle control valve will have to be sourced from somewhere else.  you  could use the barbed fitting that the valve cover breather hose goes to and run that to the idle control valve.  that hose needs to get vented to atmosphere anyways to so you  dont boost the crankcase so that shouldn't be a problem anyways.
so price on the 3.5 - 2.5 90^ elbow is $29 shipped
Todd Glazier
Danny707
« Reply #32 on: January 22, 2009, 04:13:02 PM »
I'll be in contact.
KenC
« Reply #33 on: January 22, 2009, 05:24:16 PM »
Those Flywheels look nice.  What's the weight on them?
tglaze
« Reply #34 on: January 22, 2009, 06:55:47 PM »
we typically do them at about 12lbs.  This is the best for a street car to keep a decent level of drivability.  we can do them lighter, but i wouldnt recommend it with an m42. if its going on an m20 we can go another pound or two less.
Todd Glazier
tglaze
exhaust is done
« Reply #35 on: January 23, 2009, 10:49:59 PM »
got some stuff done.
installed the catch can and m20 coolant expansion tank.  made the down pipe and full exhaust.
just need to build my MSQ file and tune, tune, and tune some more
some new pics
downpipe and exhaust are 3" fully mandrel bent with magnaflow resonator and muffler
noticed what this label on the front core support actually said, thought it was pretty funny
« Last Edit: January 23, 2009, 11:02:08 PM by tglaze »
Todd Glazier
roundel318
« Reply #36 on: January 24, 2009, 10:09:56 AM »
Nice work, love the OE sticker in the last pic, albiet out of focus....
Boosted E30
« Reply #37 on: January 24, 2009, 04:02:52 PM »
nice exhaust how does it sound pretty loud what kinda muffler did you use??
tglaze
« Reply #38 on: January 24, 2009, 05:13:01 PM »
its a magnaflow resonator and muffler.  havnt fired it up yet, still have to build my msq file.  shouldnt be too loud.  i'll post a sound clip when i get it going as well as a dyno video and what not
Todd Glazier
tglaze
« Reply #39 on: January 26, 2009, 10:15:08 PM »
got it fired up today. here is a link to the first start video.  it sounds epic, the video doesnt do it justice
http://www.youtube.com/watch?v=VJiXWN5bQY4
Todd Glazier
kevins08
« Reply #40 on: January 27, 2009, 12:25:56 AM »
thats damn clean lookin! did you do anything to lower CR(thicker head gasket, etc,) or is it all stock? how much would you say a build like this would cost both time and moneywise? and most importantly....how much hp are you expecting to get out of it?
-thanks, kevin
kevins08
« Reply #41 on: January 27, 2009, 12:38:55 AM »
scratch the cost question i didnt see that there was a 2nd page til after posting!
tglaze
« Reply #42 on: January 27, 2009, 10:20:35 AM »
compression and head gasket are both totally stock.  i wanna find their limits and then i will throw on a cometic gasket and some arp studs and turn it up a bit more.  i think with proper tuning, it should be able to handle about 12psi in stock form. that should be around 275hp at the crank, around 240 at the wheels i suppose.
we'll find out today possibly if i can get some time to do some tuning on the dyno.
Todd Glazier
kevins08
« Reply #43 on: January 27, 2009, 12:55:21 PM »
ok cool
well if all is successful, i may be interested in one if you can get that much power out of it! i am puttin my m42 in a 1974 bmw 2002, so it'll be a tight fit. how much would you sell em for if you do decide to make some more? how much boost will you be run if you put in the new head gasket?
« Last Edit: January 27, 2009, 01:28:20 PM by kevins08 »
tglaze
« Reply #44 on: January 27, 2009, 03:15:40 PM »
so..i took the car out this morning and did some freeway tuning.  this thing is pretty sick.  its making about 10.5psi with no pinging once we got the afr's tuned right.  put about 45 miles on it, so far so good.  I'm in love
Todd Glazier
