Author Topic: Tranny Removal?  (Read 2120 times)
mach schnell
  • does it fast
Tranny Removal?
« on: January 11, 2009, 03:06:11 PM »
Hi,
Is there a tranny removal DIY somewhere on this forum?
I want to drop my tranny but want to look at the procedure before I do it in case there's something that I might get hung up on without the right tool, etc.
Thanks.
1991 E30 M42
Tranny Removal?
« Reply #1 on: January 11, 2009, 04:25:20 PM »
look under the how to section. really the only special tool you will need is a set of inverted torx sockets, and alot of patience went trying to pull the input shaft out of the clutch disc.
mach schnell
  • does it fast
Tranny Removal?
« Reply #2 on: January 11, 2009, 06:02:01 PM »
Quote from: 1991 E30 M42;64475
What about the bolts holding the tranny onto the block?  How hard are they to get to?
1991 E30 M42
Tranny Removal?
« Reply #3 on: January 12, 2009, 12:26:15 AM »
I like to pull my engine and tranny at the same time because I can do it faster then trying to pull the tranny out the bottom, but I have done several in the car and I used a long extension and a swivel, the extension that I use is 36" long 3/8 drive but I suppose you can use a shorter one.
