Author Topic: Bad Differential  (Read 3350 times)
1991 E30 M42
Bad Differential
« on: January 09, 2009, 03:03:49 PM »
I broke my differential about a month ago and spent Christmas eve and Christmas night replacing it with a large case 3.73. Well i finally got around to taking my old diff apart and found a few interesting things. The pinion gear was missing a tooth, both of the side gears were missing a tooth, one of the spider gears was completely destroyed, and the carrier bearing was broken off on the side cover.
quinn11m20
Bad Differential
« Reply #1 on: January 09, 2009, 04:34:32 PM »
Wow, How did you break it? And did you try to rebuild it the same way or go with some mods. Maybe make it LSD? I want to know. I am thinking of buying a 325is diff. and replacing mine.
1991 E30 M42
Bad Differential
« Reply #2 on: January 09, 2009, 04:59:05 PM »
it just broke after 4 years of abuse, I'm not going to rebuild it, it is an lsd and the clutches and friction plates were wore out also, I replaced it with a 3.73 medium case lsd out of a 325
romkasponka
Bad Differential
« Reply #3 on: January 10, 2009, 05:07:24 AM »
Quote from: 1991 E30 M42;64382
I think you need gearbox from E36 ;)
E30 318is M42
E36 318is M44
1991 E30 M42
Bad Differential
« Reply #4 on: January 10, 2009, 12:43:40 PM »
If I was to go that route I would have to get the euro 6 speed
16v of E30
Bad Differential
« Reply #5 on: January 11, 2009, 03:38:53 PM »
so does the med case from the 325i bolt right in or are there mods needed to be done.  Im looking at getting rid of my open diff and going with either a 410 or a 373 lsd...
let me know, i want to get this done asap
mach schnell
  • does it fast
Bad Differential
« Reply #6 on: January 11, 2009, 03:51:56 PM »
Quote from: 16v of E30;64467
The medium case will bolt right in.
Boosted E30
Bad Differential
« Reply #7 on: January 11, 2009, 08:11:49 PM »
all e30 diffs are interchangeable and 5series e28 fits to you just may have to switch the back cover.
