Author Topic: Removing fan speed control switch assembly  (Read 3603 times)
achtungE30
« on: June 24, 2006, 07:07:51 AM »
I am trying to replace my heater/radio/OBC trim bezel. IN doing so, I will need to swap over the fan speed switch to the replacement bezel. How does it come out of the old one??? Looks like theres a little copper disc holding the stalk into the piece but I see no easy way of getting it out??
jakeb
« Reply #1 on: June 26, 2006, 03:54:49 PM »
You should see some little slots in that copper disc(it is a nut).  Put a screw driver in one of those slots and twist it out.
HTH
http://www.classicdaily.net - swapping this into that
http://www.blunttech.com - all your parts needs
M42boy
« Reply #2 on: June 28, 2006, 09:04:15 AM »
Quote from: achtungE30
I can guide you on this as I've got a second trim piece at home all taken apart already.  I know how to do this R&R, but can't remember off the top of my head.  If you give me a few days, I'll take pictures and post detailed instructions...  then maybe put it in the DIY section.
It's fairly easy once you know how it all goes together.  :D
achtungE30
« Reply #3 on: July 05, 2006, 01:52:57 PM »
i got it...it was indeed the slot, turn counterclockwise with a small flathead - DONE!!!
