Author Topic: Darn oil filter housing is leaking! Stupid little gasket. Any tips?  (Read 4063 times)
nomad
I figured I should have replaced it when I had the head off but Nooooo I had to get in a rush and not wait for the order.
I think I'll steam clean the front of the engine before I do this, and i might as well do it along with the E36 steering rack I just got...
Anyone know of any "gotchas" in this gasket replacement? Hope there are no stripped bolts!
SoCal, 318is: IT RUNS AGAIN!
bbarnumboy
« Reply #1 on: January 04, 2009, 02:07:32 PM »
i would also like to know some tips as i plan to do this gasket replacement in a fe days, mine leaks like a faucet on startup
E30tii
« Reply #2 on: January 04, 2009, 06:59:45 PM »
I replaced mine, it was pretty straight forward. I had to remove the alternator in order to get access to all the bolts. But everything went smoothly, I just followed the instructions in the factory repair manual. Of course now that I fixed that leak, I've got another leak from somewhere else too. Figures :mad:
KenC
« Reply #3 on: January 04, 2009, 07:10:06 PM »
Just replaced mine a few days ago... really straightforward as mentioned above.  Just remove the airbox and alternator and you have easy access to it.
nomad
« Reply #4 on: January 04, 2009, 07:18:31 PM »
I guess it gives me the excuse I needed to get the dang car up on the stands again...
« Reply #5 on: January 04, 2009, 07:28:07 PM »
You replaced the o-ring too, right?
KenC
« Reply #6 on: January 04, 2009, 08:10:40 PM »
No need to put it up on stands, and yes, I replaced the O-Ring as well.
E30tii
« Reply #7 on: January 04, 2009, 09:39:01 PM »
I also replaced the o-ring as well. No stands here either.
nomad
« Reply #8 on: January 04, 2009, 10:17:16 PM »
I'll put her back up and out of comission for a bit as i want to do E36 steering rack, e36 shift lever with rebuild and maybe a few other clean ups
bbarnumboy
« Reply #9 on: January 05, 2009, 12:49:14 AM »
o ring?????????  are you guys talking about the filter top caps large o ring?
glad to hear it is pretty easy. i take it this is a common leak?
« Reply #10 on: January 05, 2009, 02:36:03 AM »
No, there is an o-ring AND a gasket for the filter housing body.
IIRC, that upper round hole.
