Author Topic: How to change gearbox output seal?  (Read 3349 times)
Frankie
« on: January 04, 2009, 12:31:39 PM »
Does anyone has instructions for changing the seals of gearbox, I presume that name for that is output flange seal?
« Last Edit: January 04, 2009, 12:42:06 PM by Frankie »
JP 91iS
« Reply #1 on: January 05, 2009, 06:43:51 AM »
There is a good write up in the E30 Bentley, that's what I followed when I did mine.  While you are in there, you should also take care of any issues your driveshaft may need and look into refreshing your shifter bushings/install a short shifter.
If you don't have the Bentley, you can get it online here: http://www.m42club.com/forums/showthread.php?t=964
-JP
Project M42: generating funds
