Author Topic: Blow off valve ???  (Read 9110 times)
gsxrcop
Blow off valve ???
« on: January 02, 2009, 11:17:42 AM »
Hi, have a project going on a 1991 318IC. I have so far a t3/t4 hybrid turbo, good & tight manifold, 12:1 FMU, FMIC. I plan on running between 5-8 psi with this setup. My question is this...I have heard that running a AFM on this setup that I don't run a blow off valve. Is this true? Any help or advice would be great.
ludiagsm
Blow off valve ???
« Reply #1 on: January 02, 2009, 11:27:30 AM »
Quote from: gsxrcop;63879
 Hi ,if you make turbo car you must use blow off valve.
gsxrcop
Blow off valve ???
« Reply #2 on: January 02, 2009, 11:58:00 AM »
So the plan is to just take the cone filter off the intake side and install it on the turbo inlet. Take the intercooler piping right off the AFM and install the blow off valve right after that. Will that work ok? Most all of the pics I see of M42 turbo set up's must be using standalone, because they have no AFM.
bearsbmw
Blow off valve ???
« Reply #3 on: January 02, 2009, 12:09:40 PM »
Quote from: gsxrcop;63881
Blow off valve befor the AFM allways assuming you have the afm after the turbo ... if you are good with components you can even do a crude tune with the AFM if you open it up and play with the door flaper...Unfortanly when your using the Rising rate regulator there is a dead spot (Lean out) from 1-3 psi and playing with the AFM can almost eliminate the dead spot but only do this if your realy confident with your work... You can run 8psi safely with the 12:1 ... 9psi was starting to lean and 10psi I hit engine knock... good luck
« Last Edit: January 02, 2009, 12:19:14 PM by bearsbmw »
gsxrcop
Blow off valve ???
« Reply #4 on: January 02, 2009, 12:21:42 PM »
So right out of the intake do the BOV and then the AFM? What do you mean assuming AFM after the turbo? The turbo is on the other side of the engine.
Quote from: bearsbmw;63883
bearsbmw
Blow off valve ???
« Reply #5 on: January 02, 2009, 12:30:53 PM »
Quote from: gsxrcop;63884
some people rewire the AFM and put it on the induction side of the turbo...In your case you will keep the AFM in the same spot it came factory and you will place the blow off valve befor the AFM between the turbo + side and AFM
gsxrcop
Blow off valve ???
« Reply #6 on: January 02, 2009, 07:48:25 PM »
Does anyone have a pic of this set up for me to see? All of the ones I have seen have a custom intake manifold.
romkasponka
Blow off valve ???
« Reply #7 on: January 03, 2009, 09:06:26 AM »
Quote from: ludiagsm;63880
No, thats not true. You dont need it. You need it only if you want blow off dust under hood. Toys for kids...
E30 318is M42
E36 318is M44
Boosted E30
Blow off valve ???
« Reply #8 on: January 03, 2009, 01:32:53 PM »
Quote from: romkasponka;63944
if you want your turbo to last you definatly need it.
romkasponka
Blow off valve ???
« Reply #9 on: January 03, 2009, 01:49:12 PM »
Quote from: Boosted E30;63962
Ok, please tell me how much it will last longer?
E30 318is M42
E36 318is M44
bearsbmw
Blow off valve ???
« Reply #10 on: January 03, 2009, 02:29:00 PM »
Quote from: romkasponka;63966
Put a turbo with no BOV on your 318is and report back with results
romkasponka
Blow off valve ???
« Reply #11 on: January 04, 2009, 11:11:06 AM »
Quote from: bearsbmw;63970
I know few guys which are racing in Lithuanian open class championship with high boost numbers about 1.7bar without BOV and without ANY turbocompressor problems. 1000km in racing is it enough?
Nobody prooved that turbocompressor last longer with BOV.
WRC cars runs without WG ;)
E30 318is M42
E36 318is M44
Boosted E30
Blow off valve ???
« Reply #12 on: January 04, 2009, 01:34:03 PM »
good but those are race cars! this is a street car probably daily driver. my buddy didnt have bov on his turbo car and his brand new turbo was done in 2months
nuvolarossa
Blow off valve ???
« Reply #13 on: January 04, 2009, 02:48:34 PM »
Quote from: romkasponka;64038
I think that 1000km in racing doesn't mean that a stock engine and turbo without bov will last enough... :confused:
Yes, but they have this ;)
http://forums.nasioc.com/forums/showthread.php?t=1650384
If you don't want to use a BOV venting to atmosphere and making noise, place a BPV (aka diverter, aka recirc-valve, the ones that bosch make for stock turbo cars like Porsche TT, VAG 1.8T...) they are quiet and they do fine their work.
like this:
:rolleyes:
« Last Edit: January 04, 2009, 02:50:40 PM by nuvolarossa »
gsxrcop
Blow off valve ???
« Reply #14 on: January 04, 2009, 09:55:48 PM »
Thanks for the comments. I'm going to use a BOV, it's a HKS. What I still need is a picture or more info on where to place it when running a AFM. Any help?
