Author Topic: REAL Cold Air Intake  (Read 14364 times)
1991 E30 M42
« on: December 31, 2008, 06:57:24 PM »
I decided to make my own real cold air intake with heat shield and external air source. It works great too, I'll open the hood after a long hard drive and the engine will be hot and the uper and lower intake will be cold, I drove it to Virginia Tech a couple months ago, and on the way back the throttle body started to ice up and I had to stop and let it warm up. It is made of real carbon fiber and I cut up a hood seal and used that to seal the intake from engine heat. As you can see in the lower picture, it makes a positive seal with the hood. If anyone is interested in one let me know, I might be willing to make some.
« Last Edit: December 31, 2008, 07:00:13 PM by 1991 E30 M42 »
Danny707
« Reply #1 on: December 31, 2008, 07:27:11 PM »
Wow that looks really nice.
kamotors
« Reply #2 on: December 31, 2008, 08:58:13 PM »
wow, looks great, i wish the M20 had that kind of room, great job.
400+WHP M20 turbo
PM me to BUY kamotors fender flares
ver.4 C.F. CAI here
"LIKE" KAMOTORS Performance-parts on Facebook
gjuuu
« Reply #3 on: January 01, 2009, 07:13:52 AM »
Quote from: kamotors;63809
There is plenty of room with the m20 - just as long as you have the radiator with the built in reservoir, no abs and no cruise control :)
1991 E30 M42
« Reply #4 on: January 01, 2009, 12:51:26 PM »
looks like an m42 radiator, you can also get the 666fab reservoir that mounts on the passenger side.
nomad
« Reply #5 on: January 01, 2009, 03:05:24 PM »
ABS is in the way on mine...
SoCal, 318is: IT RUNS AGAIN!
Danny707
« Reply #6 on: January 01, 2009, 03:30:58 PM »
You could work around the ABS fairly easily.
kamotors
« Reply #7 on: January 01, 2009, 04:13:03 PM »
Quote from: gjuuu;63819
very true. great job on yours also. I was working on a carbon fiber Cold air box, I designed it in 3d but never got around to actually making one.
« Last Edit: January 01, 2009, 04:15:07 PM by kamotors »
400+WHP M20 turbo
ver.4 C.F. CAI here
1991 E30 M42
« Reply #8 on: January 01, 2009, 11:33:27 PM »
I have abs, the filter sits on top of the of the abs module. I used carbon fiber as apposed to plastic or fiberglass because of its insulation properties
roundel318
« Reply #9 on: January 02, 2009, 10:31:13 PM »
I love ABS :)
Ruger
« Reply #10 on: January 09, 2009, 10:26:03 AM »
Ive got a similar airbox but a custom fibreglass one shaped as a big velocity stack and what i also did which helped was tilt the radiator about 20 degrees (with custom mounts) and have a 3" pipe going direct into it and it picks up air from where the kidneys are. With this setup and the shape of it all it keeps air speed up as high as possible.
Definately an increase over K&N in the stock box. Most ppl will tell you otherwise but its worth the effort.
bearsbmw
« Reply #11 on: January 09, 2009, 10:50:42 AM »
Quote from: 1991 E30 M42;63805
Nice setuP!! ... however with the AFM turned on it's side like that it's changing you fueling because of the weight of the door flaper
1991 E30 M42
« Reply #12 on: January 09, 2009, 12:04:42 PM »
Quote from: bearsbmw;64372
Its not changing the fuel, I ran several tests on the dyno with a data logger and if anything changed it was so small that I couldn't see it. I also played around with fuel pressure and found that 43 psi (3bar) was not optimal and picked up 10 horsepower and a falter curve by bumping it up to 50 psi.
bearsbmw
« Reply #13 on: January 09, 2009, 02:00:07 PM »
Quote from: 1991 E30 M42;64373
Intresting! there would be a change but like you said very small and I should have mentioned... nice work anyways
gtatbrissy
« Reply #14 on: July 23, 2009, 02:37:15 AM »
that looks awesom, where did u get the cf from or did u make it urself
