Author Topic: Operation E30M42T - New Guy Seeking Inputs/Comments/Advise  (Read 1880 times)
BAGMF0
« on: December 30, 2008, 12:42:56 PM »
Well, Finally going to try and satisfy my E30 M42 Fetish!!  Hopefully the experts of this board can help steer me in the right direction if I start to head in the wrong direction!
Here is a list of thing I plan on doing to my E30.  Please give me your inputs/thoughts to similar items on your cars and/or experiences you have had with them (good & bad).  Items in green are already on hand items in red need to be purchased...
BODY:
   - Flares (Modified 2002turbo)
   - Rear wing (replace stock - mine is a lil warped)
   - Headlights (Smoked Euro Smileys - Hella's)
   - Euro Grills
   - Front Chin Spoiler (either the stock tall guy or ????)
   - Fog Lights (replace stolen ones - BASTARDS!!)
   - Rear-View Mirror w/Map Lights
   - Smoked Tail & Driving Lights
   - Euro BBS Mesh Wheels (15" deep-dish Mesh)
SUSPENSION:
      FRONT
   - M3 Lower Control Arm Bushings
   - New Lower Control Arms
   - Schnitzer/Bilstein Coilover Struts
   - Adjustable Camber Plates (Ground Control)
   - New Tie Rods
   - New Sway Bar (19mm)
   - New Wheel Hub/Bearing (OEM)
   - New Springs (2.5" - 550lb)
   - Strut Brace
      REAR
   - New Wheel Bearings
   - Urethane Trailing Arm Bushings
   - Adjustable Camber/Caster Kit
   - New Sway Bar (22mm)
   - 2.5" Spring Perch Conversion
   - New Springs (2.5" - 650lb)
   - New Bilstein Shocks
   - Replace Rear Trailing Arm (Bent)
   - Swap Rear Diff (325i diff w/4:10 LS)
   - Strut Brace
BRAKES:
      FRONT
   - Vented Rotors
   - New Brake Pads
   - Paint Calipers
   - Stainless Lines
      REAR
   - Vented rotors
   - New Brake Pads
   - Paint Calipers
   - Stainless Lines
ENGINE:
   - K&N Air Filter
   - Cold Air Intake
   - Exhaust
   - BMP Re-Map Chip
   - Oil Cooler (BMW OEM)
   - New Hoses
   - New Belts
FUTURE UPGRADES:
   - Engine Rebuild (M44 - lower CR)
   - Custom Turbo
   - Intercooler
   - Serpentine Belt Setup (will come with the M44)
   - Roll Cage
   - Big-Brake Upgrade
   - Carbon Fiber Hood
   - Carbon Fiber Decklid
   - Chandelier
   - Keg Tap
Thanks in advance for any/all inputs!!!  I made the color changes to the text.. and it muck'd up the format - curious to see how it will look once I post!?
Ciao
BAGMF0
Five Lug Conversion....?
« Reply #1 on: December 30, 2008, 12:52:13 PM »
OK...I have two sets of E30 M3 5 lug wheels & a complete rear subframe off of a Z3 which would work out perfect with the addition of my fender flares (wheel offset, etc..)
I would like to use my ACS Coilover front struts :)!
Can I but the 5-lug M3 hubs on a 4-lug strut spindle?
I wouldn't be able to use my BAD-ASS deep dish 4-lug 15" mesh wheels, but the offest would work out better with the M3 wheels - and I would have a set of street tires/wheels & track tires/wheels... :D
Bennies/drawbacks!?!?  Inputs?!!?  I know this has been hashed and re-hashed... but parts are becoming more accessable, so i though i would ask with todays parts availibility....
Ciao!
