Author Topic: Got Shaft? (E30 Driveshaft differences)  (Read 7197 times)
Nomadic
« on: December 30, 2008, 03:40:45 AM »
There are two part #'s for e30 M42 driveshafts (aka propshafts )
AC Cars - 26111227012
non AC - 26111227014
Are they interchangeable?
I may be looking for a used or rebuilt drive-shaft for my 91 318is in the near future.  (CSB)  I'm wondering how hard it would be to find a good used driveshaft that fits.  Are there lots of differences between years/build-date/models/coupe/sedans ??
Can I assume that late-model m20 E30 drivelines WON'T FIT our M42s?   RealOEM lists different part numbers for late m20/m42 for complete driveshafts assbly but many of the individual parts are the same.
They also list different part#'s for AC/non-AC for my  m42 318is.  WTF ????   and What's up with those big honking harmonic balancers?
MANUAL DRIVE SHAFT
26111227014  $719.82
FOR VEHICLES WITH
AIR CONDITIONING S530A=YES
DRIVE SHAFT ASSY
26111227012 $666.81
If used driveshafts aren't worth the trouble of sourcing .... do I need to send out to a driveline service that specializes in BMW (Driveline service in Portland ) or can a local Seattle shop do a good job with BMW shafts?
Cheers!
« Last Edit: January 05, 2009, 06:04:06 PM by Nomadic »
papercutout
« Reply #1 on: December 30, 2008, 02:58:48 PM »
In the UK the driveshaft goes between the diff and the wheel hubs, and these all seem to be interchangable, I've replaced 3 on mine so far (CV joints going).
If its the propshaft (gearbox - diff) then they change between 4pot and 65 pot engines for definite, you can PROBABLY use any 4 pot one, but don't quote me. Better safe than sorry and putting a wanted ad up for one?
Or am I still getting the wrong bit?
Nomadic
« Reply #2 on: December 31, 2008, 01:40:12 AM »
Quote
Bastardizing English has been a sport in America so long... we forget we're doing it...   We could use German, but I'm not sure if Antriebswelle, translates to half-shaft, prop-shaft, drive shaft or if its German porn slang...
I'm talking about the bloody expensive one!
Like the drive-shafts (realOEM terminology ) ... RealOEM lists two different updated transmission part#'s for the USA E30 m42 manual overdrive Transmissions:
- 23001222035 240/5.62-TBCU for AC
- 23001222032 240/5.61-BCT nonAC
....  I cant fathom why this would be.   What difference could the AC make in the driveline? Do the USA non-AC cars come with some super-secret rally-spec drive line?  PM and I'll keep this quiet ...
Surely someone here has swapped driveshafts.  Are there any really differences between E30 m42 ac/nonAC?
Thankfully have not found any different part#'s between e30 m42 production dates or sedan/coupe body styles.  The  only difference  seems to be AC non-AC.
Cheers,
« Last Edit: January 02, 2009, 10:24:16 PM by Nomadic »
papercutout
« Reply #3 on: December 31, 2008, 12:01:22 PM »
You said it, not me ;)
We just nicked French, Greek and Latin words for our language! Anyway, explain in plain terms what driveshaft it is that you want, where does it come from/go to? The prop shaft down the centre of the car?
On the realoem website it showed a pic of a gearbox with 5 part numbers underneath in a green and purple chart, 2 of which were damned expensive (near $2500) 2 others weren't, due to being obsolete, and the 5th was just a bearing.
Link I got upon search for the long part number:
http://www.realoem.com/bmw/showparts.do?model=AG71&mospid=47294&btnr=23_0290&hg=23&fg=05
Clarification?
Nomadic
« Reply #4 on: January 02, 2009, 10:29:38 PM »
Yup,  I'm talking about the drive-shaft that runs down the center with guibo's & u-joints and CSB.
I didn't mean to muddy up the conversation with transmission talk.... I was noting that USA AC/non-AC cars have different transmission #'s as well as different driveshaft #'s.  The situation might be different for UK/Euro cars.
I have an US E30 318is with factory AC... and I'll bet the vast majority of USA E30 318i/318is came with AC.
I'd like to know if anyone has personal experience with E30 M42 AC/nonAC driveshaft differences.
I'm not a big fan of crawling under cars.... so I don't want to do this twice.
Cheers!
« Last Edit: January 05, 2009, 05:58:09 PM by Nomadic »
papercutout
« Reply #5 on: January 03, 2009, 03:46:40 AM »
No, you don't, trust me, its a pig! I ended up having to undo the rear gearbox mount, and so tilt that and the engine down slightly to get a decent angle to get the driveshaft out with the downpipe still there.
It SHOULD be no different. But being a non-AC spec, obviously I can't confirm. I can't imagine it'll make a difference to the propshaft though?! Gearbox to diff, unless the linkage in the gearbox is slightly different.
Nomadic
« Reply #6 on: January 04, 2009, 03:59:53 PM »
bump-  anyone?   Are the two different drive-shafts PN#'s interchangeable?
goforwow15
Good point.
« Reply #7 on: January 04, 2009, 04:20:44 PM »
batsbats
« Reply #8 on: January 10, 2009, 12:13:38 PM »
Quote from: goforwow15;64074
Good point. Bump Up!world of warcraft gold wow gold cheap wow gold buy wow gold cheap wow gold
spam, mod delete
