Hi All
Got the timing case welded up and the parts arrived to replace the chain, sprockets and guides. Even installed profile gasket using the feeler gauges.
The new parts look different to the 18 year old originals
1/ the crankshaft sprocket has a rubber seal/ring bonded to the front and rear that almost cushions the chain
2/ the guide rail has an adjustable screw at the top position to align the guide
Normal...?
Also, how to prime the oil circuit?
when the idler gear boss fractured and the teeth chewed into the case, I collected the grindings from the sump, oil filter housing and the oil pickup screen, hoping that none had entered the gallery, main/crank/cam bearings
But when I rotated the engine on the crankbolt there was a lot of resistance to movement. Eventually freed up with some WD40 on the exhaust valve stems and was able to spin on the starter. I could hear a burp and fresh oil appeared to splash out from the chain tensioner.
The engine had been laid up, under cover since May this year.
