Changing Headlight Bulbs?
Author Topic: Changing Headlight Bulbs?  (Read 3584 times)
Interlocker
« on: June 21, 2006, 05:56:34 PM »
Two weeks of ownership and I finally have to do something to it... change one of the headlight (low beam) bulbs.
The owner's manual makes it look as though I have to remove the front grills?  Is this all pretty straight forward and intuitive once I pop the hood and start poking around?
Thanks
« Reply #1 on: June 21, 2006, 07:11:00 PM »
well...do you have ellips or sealed beams?
Interlocker
« Reply #2 on: June 21, 2006, 08:53:54 PM »
Quote from: asubimmer
Whatever came to the U.S. from the factory.  ;)  They don't have the smile, if that helps.:confused:
« Reply #3 on: June 21, 2006, 08:59:56 PM »
Is the bulb removable form the back, or is the back all glass with 3 prongs sticking out?
« Reply #4 on: June 21, 2006, 10:05:21 PM »
sounds like you have the sealed beams.  Those are the stock headlights for a 318is.  You will have to take the grill off to change them but I HIGHLY recommend switching to either euro or us ellips.
