Author Topic: Stalling/bogging down at idle  (Read 3542 times)
doublebassdanny
« on: December 17, 2008, 01:59:07 PM »
Greetings all, this is my first post here:
It's been getting cold where I live, and my 1991 318iC has been starting a bit sluggishly but then runs just fine. Today however, I started her up and went inside for a few minutes to let it warm up, when I came out she was bogging down every couple of seconds (almost to a stall), and when I sat inside after a minute or two it died. I started it back up and put the gas on, as that seems to keep it running pretty well. I drove off to work and at every stop felt it bog down almost to a stall unless I kept the revs up (but with the revs up I felt something "odd"). The check engine light flipped on at one stoplight while I was waiting, but disappeared after I was accelerating. This continued even after the engine was warm, but now I just went out and everything seemed fine, only a very minor rev level drop. Any ideas? I see a very, VERY small crack around the rubber boot near the hose clamp, but that's all as far as intake issues. I have a cracked oil filter housing, so I see some oil below that that has leaked out, although I don't think that's a problem as my oil level is just fine.
Any suggestions would be greatly appreciated, thanks!
roundel318
« Reply #1 on: December 17, 2008, 02:22:30 PM »
There are some rubber hoses for your ICV (end of valve cover to ICV then ICV under intake to "medusa" or "the mess under the intake") which consists of a selection of rubber hoses that cause vacuum leak problems and subsequently since this is for the ICV (Idle Control Valve) is prone to causing idle issues.
Aside from that, the usual spark, fuel, ecu, voltage, etc can cause problems (this list goes a ways beyond "etc")
However with your bogging etc and the rubber intake book crack, you should address that first.
  • -Receive: 5
« Reply #2 on: December 17, 2008, 02:37:12 PM »
Read through the thread in my signature. Good luck.
doublebassdanny
« Reply #3 on: December 17, 2008, 03:25:22 PM »
Thanks guys. Hopefully I can find an intake boot around here (Kansas City, MO). That's fairly simple to replace, eh? I'm an utter noob, but hope to do as much work myself since I'm in college and low on cash pretty much all the time :)
Also, am I going to make anything worse by driving it? It's working more or less fine right now, so I was planning on driving it around after work to see if anything changes for the better or worse and in what conditions.
roundel318
« Reply #4 on: December 17, 2008, 10:23:39 PM »
Stay out of the throttle and revving high, it could hold out.
Really bad when parts break off going into the engine....
roundel318
« Reply #5 on: December 18, 2008, 07:30:21 AM »
Quote from: hijk578;63107
be sure to use styling tools specially made for lace wig such as a wig styling comb, wig brush or wig pic comb.  Caution:  When styling synthetic lace wigs never use heating styling tools on your wig or expose your full lace wigs to excess sources of heat such as:  Hair dryers, curling irons, open ovens, boiling water, barbecue grills and even some cigarette lighters, because the heat will damage the fibers.  When styling human hair wigs you can use all the tools you have used on your own hair (hair dryer, curling iron, hot rollers) and do not need to worry about heat exposure, but must use products especially formulated for lace front wigs.
evil spam!
