Author Topic: Med or Small case LSD? Can use either?  (Read 2246 times)
nomad
« on: December 17, 2008, 12:56:42 AM »
So which one should I get? I read that ours has the small case but the med case is interchangeable? I also read that the med case is easier/cheaper to buy replacement friction packs for and the small case is weaker.
Anything I should look for?
SoCal, 318is: IT RUNS AGAIN!
nomad
« Reply #1 on: December 17, 2008, 07:17:39 PM »
so which one is better for the M42? I'm leaning towards the Medium case as i can get new clutch plates easier
szed03
« Reply #2 on: December 21, 2008, 07:30:15 PM »
Nomad, go with the medium case!  No question.  WAY more ratios and LSD options.  I'll be putting in a 3.91 lsd out of a 325 really soon.  This is on an e36 by the way.
Are you doing this on an e30 or e36?  e30 I believe has a few options such as a 4.10 and 4.45 (???)  I'll have to do some cross referencing on the ETK.  I'm more familiar with the e36 diff swap though.
Where in Socal are you?  PM me if you'd like some help with the swap! :D
nomad
« Reply #3 on: December 21, 2008, 07:47:56 PM »
Thanks, I'm looking to keep the 4.10 but with LSD.
I don't mind high revs if it gets me off the line and into the powerband better.
I was looking at the med case due to availability of rebuilding.
Thanks for the advice. I'll let you know when I get one.
First on the list is putting in the E36 steering rack I just picked up.
