Author Topic: HELP! 90 318is oil leak / oil coming out of dipstick tube!  (Read 2541 times)
tbsol
« on: December 15, 2008, 01:06:21 PM »
I have a 1990 bmw318is.
The temperature was -44 celsius here last night. :eek:
I started the car in the morning & noticed oil leaking from around one of the valve cover gasket bolts that never leaked before. I also noticed there was a lot of pressure/oil coming from the oil dipstick when i removed it.
What would cause such an excess of crank case pressure?
Argh.. I've only had the car 2 weeks and having problems already.  :(
Please help!
Could this be caused by a stuck pcv valve? Or something that froze up?
I was told that the E30 doesn't use a PCV valve.. is this true?
any suggestions/tips?
I'm really hoping I can just give it a fresh oil change and a good unthaw and everything is going to be alright...
any help would be greatfully appreciated.
-chris
batsbats
« Reply #1 on: December 15, 2008, 03:20:18 PM »
...-44 CELSIUS????
I didn't know auto engines were supposed to be cranked or even used at those conditions.
batsbats
« Reply #2 on: December 15, 2008, 03:21:10 PM »
repost
« Last Edit: December 15, 2008, 03:22:24 PM by batsbats »
bearsbmw
« Reply #3 on: December 15, 2008, 04:10:30 PM »
a -44 crank is instant engine death!
tbsol
« Reply #4 on: December 15, 2008, 05:24:54 PM »
I guess I should have also included I'm from Winnipeg Manitoba Canada and the temperature's lower then -30 C are a common occurance here in the winter months.  It was -44*C with the windchill factor... ~ -34*C without.
The car had a block heater plugged in all night too to keep the engine warm and ensure that the coolant didn't freeze.
this weeks weather:  :(
http://www.weatheroffice.gc.ca/city/pages/mb-38_metric_e.html
roundel318
« Reply #5 on: December 16, 2008, 11:12:55 AM »
Your block heater should keep it warm enough to start :)
