Author Topic: E30 M42 ICV/plumbing questions  (Read 6727 times)
longms
« on: December 12, 2008, 07:10:55 PM »
I am sure this has been covered before but I need to know where a couple of things mount and connect.
I need to know where the hose on top of the ICV connects and what all the mounting hardware mounts to (in the picture below)? Thanks for the help. This plumbing is the only thing holding back my car from starting right now.
If anyone has there intake assembly off for any reason and would be so gracious to take a picture of how the plumbing/piping is situated that would be awesome. I can't seem to figure out how it all goes under the intake.
JP 91iS
« Reply #1 on: December 12, 2008, 07:18:03 PM »
Upper hose attaches to intake manifold, mounting bracket attaches to the bolt that mounts upper to lower manifold.
-JP
Project M42: generating funds
twright
« Reply #2 on: December 13, 2008, 07:19:30 AM »
Please be sure to mount the IGV with the arrow pointing "Down".  It will run a lot better if you do this.  (Don't ask me how I know.)
longms
« Reply #3 on: December 13, 2008, 09:13:26 AM »
Quote from: twright;62738
Seriously?????
roundel318
« Reply #4 on: December 13, 2008, 09:53:18 AM »
Correct, the end with the smooth hose feeder part goes up (they suggest a hose clamp even) to the valve cover and the end with the ribbed feeder part goes down to the Medusa, or "the mess under the intake" :)
twright
« Reply #5 on: December 13, 2008, 05:49:57 PM »
My IGV was connected the wrong way.  I was having problems with rough running after a warm start.  It is getting better after I reversed the direction of the IGV.  I still have a problem, but this helped.  (I don't understand why it would make a difference, but it does.)
longms
« Reply #6 on: December 13, 2008, 10:24:08 PM »
Good looking out to you guys. About to fire up a 2 year project and trying to tie up the loose ends. Working at a snails pace sucks and it also doesnt help that I live in a different city than the car is in.
Cobra Jet
« Reply #7 on: December 15, 2008, 11:30:36 AM »
mount the ICV w/ the arrow down???
exactly what arrow is being referred to?
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
longms
« Reply #8 on: December 15, 2008, 02:40:39 PM »
There is physically an arrow stamped on the housing of the ICV. They are saying to mount the ICV with the arrow pointing down.
BraveUlysses
« Reply #9 on: February 16, 2009, 11:57:42 AM »
Bump
Is this actually correct? My understanding is that the ICV arrow should be pointing with the flow going from the intake TO the manifold.
http://www.m42club.com/forums/showpost.php?p=49362&postcount=30
JoeDellio
« Reply #10 on: February 17, 2009, 12:00:41 AM »
It says right in the manual that the arrow needs to point up.
[SIGPIC][/SIGPIC]1995 318i
strad
« Reply #11 on: February 17, 2009, 12:21:27 PM »
Arrow points in direction of airflow.  That's towards the manifold side of the valve.  I've no idea if that is "down" or "up" since I can't see it on my M42 (even though I've r/rd it correctly lol).  But my M20's is in plain view, and that's how it is oriented.
« Last Edit: February 17, 2009, 12:25:17 PM by strad »
