Author Topic: trouble undoing lower wishbone bolt? e36 318is  (Read 2630 times)
antony_e
« on: December 12, 2008, 01:10:53 PM »
hi guys i think this is my first post but anyway hi :D bit of a dilemma however im trying to remove my nearside lower wishbone after a slight ice incident but my main issue is i cant undo just one bolt. ive circled the end of the arm below that im having trouble undoing,the only part that i can get on has rounded and now im stumped as to how to get it out?
any suggestions greatly appreciated
thanks - ant
ooops maybe not my first post but oh well
« Last Edit: December 12, 2008, 01:11:31 PM by antony_e »
Deftones
« Reply #1 on: December 22, 2008, 03:23:24 PM »
on my ex M3 i had to remove the differential... in the 318is which has got a smaller diff i don't know if you can do it anyway, so i suggest you to loose the diff bolts without removing it, push it as far as you can from the wishbone (it moves just 1 inch) and then try to loose the bolt #14; the piece #15 cannot rotate cause it is blocked in a little hole of the diff cage.
anyway that bolt requies a lot of time to be removed
« Last Edit: December 22, 2008, 03:28:37 PM by Deftones »
http://blogs.yahoo.co.jp/luca318is
1992 318is e36
1990 318is e30
