Author Topic: rough idle//stalls out at stops  (Read 6672 times)
roundel318
« Reply #15 on: December 16, 2008, 09:34:52 PM »
Do you have A/C?
If the idle is being wack and you turn on the A/C, what happens?
stereomotional
« Reply #16 on: December 18, 2008, 01:47:47 PM »
a/c is deleted
mkIV Jolf 1.8t (the DD)
rallyegolf
« Reply #17 on: January 06, 2009, 09:45:13 AM »
I think I am having the same issue with my E30. I will tell you what I find out, and maybe you are having the same issue.
thanks
doitover
« Reply #18 on: January 06, 2009, 10:46:15 AM »
Icv?
jrobie79
« Reply #19 on: January 06, 2009, 03:59:04 PM »
join the club man...
http://www.m42club.com/forums/showthread.php?t=6553
http://www.m42club.com/forums/showthread.php?t=6077
if you figure it out, you would help a good deal of members on this board
AcSchnitzer318is
« Reply #20 on: January 07, 2009, 12:03:46 AM »
LOL... so many threads... so man sufferers.  I've learned to live with it now I guess since I am working more and don't have time to mess with it anymore.  I am in the same situation in that I swapped a motor that had no problems (22k mile fresh rebuild) into a chassis that did... now this motor does what the old one did.  So it is something COMPLETELY external to the motor causing this issue.  Things it is NOT...
vacuum leak
ECU
ICV
AFM
TPS
CPS
FPR
injectors
roundel318
« Reply #21 on: January 07, 2009, 01:56:34 PM »
This page on the thread
http://www.m42club.com/forums/showthread.php?t=6553&page=3
I know AcSchnitzer318is has covered this on the thread, have some of the chassis related idle shit newb's gotten a visual here.
Also the loss in residual fuel pressure is possible, but would be beyond the FPR as AcSchnitzer318is has that on the list.
Has someone tried a spare ECU AFTER the fusebox soldier?
Perhaps the ECU is effected by an electrical short etc from the fusebox situ ?
Just tossing more ideas out for people to play with.
I am pretty comfortable with the theory of it being inter-related to the chassis as more than one person has experienced this post swap?
roundel318
« Reply #22 on: January 08, 2009, 04:33:32 PM »
Also, nofear has been making headway on his...
http://www.m42club.com/forums/showthread.php?p=64340#post64340
rallyegolf
« Reply #23 on: January 13, 2009, 10:32:07 PM »
I bet you have a bad ground, or maybe something in the fan is wired up incorrect so when it is getting power, it is correcting the ground. Maybe????
 I am just throwing something out there to see if anything stick. hahah..
Did you test your grounds?
roundel318
« Reply #24 on: January 24, 2009, 09:57:35 AM »
Do you have the factory electrical documentation?
