Author Topic: Two small turbo related questions  (Read 3827 times)
nuvolarossa
« on: December 09, 2008, 04:33:51 PM »
QUESTION #1 TB INTAKE BOOT:
I need to buy a silicone hose reducer to swap the rubber intake boot, as it will explode under boost. Who bought it can tell me the internal diameter on the throttle body side? Need to know if a 3,5" ID is the right size or if it needs something smaller as I only "eye-measured" it... I need to reduce it to 2" pipe.
QUESTION #2 OIL PAN
people here with turbo e36 can show me where you drilled the oil pan for turbo discharge?
Christmas holidays may be boosted :D
thank you
bearsbmw
« Reply #1 on: December 09, 2008, 05:31:52 PM »
Quote from: nuvolarossa;62523
QUESTION #2 OIL PAN
thank you
You can run that stock boot easly with a little modification and black hockey tape but if it's super old I wouldnt... mine see's boost all the time... It's nice to keep it and not re-route the ICV... when I presurized my intake to check for leaks the boot easly took 20psi with my simple modification... as for the oil pan you will see step up's to where the oil pan gasket is and on the last step up is where I did a tap.. I should mention you get one chance at the tap and it has to be perfect or you will find yourself geting a bung welded
« Last Edit: December 09, 2008, 06:26:19 PM by bearsbmw »
strypt
« Reply #2 on: December 10, 2008, 03:14:31 AM »
This is how i made my installation w/o a boot. But you'll need a tig welder...
Edit: Hm attach photo didn't work..
nuvolarossa
« Reply #3 on: December 10, 2008, 03:46:43 AM »
Quote from: strypt;62564
Thanks, as I don't have TIG I'll do like that to the next TB, I have three of them:D but I'm out of home for a week and can't measure :(
For now I want to know what size of silicon reducer will fit ;)
(sure with TIG would be the best)
Quote from: bearsbmw
I'll do higher I can ;) sure, it's not the first pan that I tapped, it's only that I don't know where is the oil level inside the pan and how is the interior of the pan :D
« Last Edit: December 10, 2008, 04:10:12 AM by nuvolarossa »
bearsbmw
« Reply #4 on: December 10, 2008, 10:38:15 AM »
take your oem boot off and messure the throtle body part like a taylor would messure your waist...oil level inside is erelivant when the car is off as it has all fallen back to the pan...if you tap where I told you, the oil will make a safe loop while the car is running
nuvolarossa
« Reply #5 on: December 10, 2008, 11:39:12 AM »
Ok, I understand.
Will a standard drill fit in there or the small angular(I don't have this) is required? just don't remember the space and the car is a lot of miles far from me now :(
bearsbmw
« Reply #6 on: December 10, 2008, 12:17:42 PM »
small standard air drill was used on mine... Do you have any base map's for the m42? ... Good luck!
nuvolarossa
« Reply #7 on: December 10, 2008, 01:11:41 PM »
Quote from: bearsbmw;62585
I don't need the base map :D using a piggyback (PCIII) but it does only fuel. I modified it to raise or lower fuel RPM and MAP based instead of RPM and TPS... you'll see my posts next weeks with all details.
If just I can find a easy and not too expensive spark retard unit it would be great, so I can retain the stock ECU for MOT issues and use the other two piggybacks to run the engine better if I need to raise boost to 12-15psi. (As I have a T3 60 trim ;) )
