Author Topic: Ignition Coil Code  (Read 2584 times)
KenC
Ignition Coil Code
« on: December 03, 2008, 02:33:21 AM »
My motronic is throwing a 1271 code, which I found on the web to indicate a malfunctioning Ignition Coil #1.  I replaced the coil today, verified that it's sparking, and it's still throwing the code.  What gives?
nicknikolovski
Ignition Coil Code
« Reply #1 on: December 03, 2008, 02:41:45 AM »
Don't you have to clear the code? Or did you do that?
KenC
Ignition Coil Code
« Reply #2 on: December 03, 2008, 12:41:54 PM »
Clear it?  How do I do that?
JP 91iS
Ignition Coil Code
« Reply #3 on: December 03, 2008, 01:33:33 PM »
Quote from: KenCopperwheat;62178
From the PelicanParts article:
Quote
Make sure that the last code (1000) has occurred, and then press down on the gas pedal for more than 10 seconds.  This should clear out the memory of the DME.   Repeat the fault code reading process, and the computer should generate code 1444, which means that there are no faults stored.
-JP
Project M42: generating funds
KenC
Ignition Coil Code
« Reply #4 on: December 03, 2008, 04:51:29 PM »
That reset doesnt seem to work... it just keeps throwing the code.  Can I just unplug the ecu for a bit?
roundel318
Ignition Coil Code
« Reply #5 on: December 03, 2008, 11:46:38 PM »
you may be able to clear it by unplugging it, but usually you need a tool.
the holding gas pedal 10 seconds after to reset didnt work for me either.
Danny707
Ignition Coil Code
« Reply #6 on: December 04, 2008, 12:29:10 AM »
Try unplugging the battery over night.
