Author Topic: Any companys make Throttle body spacers?  (Read 4965 times)
ajatya2
« on: December 01, 2008, 10:03:22 PM »
Ive been looking around to try to find a throttle body spacer?
NO LUCK AT ALL!
Any one know a place to get one? :confused:
94\' E36 318is
« Reply #1 on: December 01, 2008, 11:50:05 PM »
What does a throttle body spacer do exactly?
JP 91iS
« Reply #2 on: December 02, 2008, 12:03:35 AM »
They were originally invented for engines with carburetors. They bolt between the TB and intake manifold -there are claims that they increase air volume / change air flow patterns to increase hp, torque and mpg.   To me they mostly sound like garbage "cheap hp" mods.  In truth I think they can be effective on certain applications, of which ours is probably not one.
edit: If you wanted you could just leave your TB heater plate in and it would work just as well...
« Last Edit: December 02, 2008, 12:10:10 AM by JP 91iS »
-JP
Project M42: generating funds
ajatya2
« Reply #3 on: December 02, 2008, 12:46:34 AM »
yea personaly i dont think it will do much either but if i can find one cheap why not its worth a try. I have nothing els to put on that would be cheap other than a tbs. I just wana find one
94\' E36 318is
nomad
« Reply #4 on: December 02, 2008, 01:00:19 AM »
Want my TB heater plate?
Stack two up and you have a nice billet aluminum spacer.
SoCal, 318is: IT RUNS AGAIN!
ajatya2
« Reply #5 on: December 02, 2008, 01:05:18 AM »
how much?
94\' E36 318is
xwill112x
« Reply #6 on: December 02, 2008, 12:20:43 PM »
tb spacer makes it sound like you have a turbo...no gains. ive seen many efi applications with no dramatic increases in power before/after the spacer.
Ich liebe meinen E30
roundel318
« Reply #7 on: December 02, 2008, 08:20:08 PM »
it sounds like just making intake runners longer to adjust the powerband config.
txleadfoot
    • Google Profile
« Reply #8 on: December 02, 2008, 08:53:51 PM »
what's this panic about the spacer?  essplain.
1991 E30 M42
« Reply #9 on: December 03, 2008, 01:44:12 AM »
As roundel said, it is like making intake runners longer. Longer runners are good for low rpm power and short runners are good for high rpm power. The same applies for exhaust manifold/header. You can also change plenum volume and shape, as well as intake port size and shape. Metric mechanic has an interesting intake manifold design which incorporates pulse chambers.
http://metricmechanic.com/pdfs/metric-mechanic-m42-and-m44-engine-booklet.pdf
Check out page 14
ajatya2
« Reply #10 on: December 03, 2008, 12:45:11 PM »
yea i was looking to get the intake to run longer. and i realy dont know why i phrased it the way i did im not realy in a hury for one. lol and its not boosted. yet.
94\' E36 318is
