Author Topic: 91 318is fuel problems  (Read 14848 times)
brian-pat91-318
« Reply #15 on: November 20, 2008, 05:15:08 PM »
Quote from: RED IS 91;61362
Dropping the tank on these cars is quite a process but if your going to replace everything then have at it.Personally ,if it ain't leaking fuel then I'm not removing the tank.There are some write ups on it if your feeling frisky.
good luck[/QUOTE
damn that sucks. well i wouldnt drop it if it didnt have rust. besides dropping it is there anyway i can clean it out? lol thats somewhat of a stupid question. well even if i drop the tank do you know of any methods of cleaning it?
and no it doeasnt buzz when the car is on only when i hook it up to a different neg. and pos. lead.  which makes me think that there is a problem with the grounding of the connector or something. otherwise idk what it would be besides the relay or fuse.
maggieEric53
bmw e30 318i 1991
« Reply #16 on: November 22, 2010, 08:27:41 AM »
i have a bmw e30 318i 1991 i replaced the airflow hose at the weekend after doing so i went to start my car and it just cranked over very strongly but will not fire up please help as i depend on my car as i am disabled Eric
« Reply #17 on: November 22, 2010, 06:11:51 PM »
Now that's a thread back from the dead.  BTW, if the original poster ever comes back to check, I'm 99% sure it's your crank position sensor.
maggieEric, you'll have to make sure all the vac hoses are tight.  Big vacuum leaks can prevent the engine from starting.  Which hose are you talking about, the main hose from the air cleaner to the throttle body?
