Author Topic: Cold start engine shakes and sputters  (Read 27378 times)
roundel318
« Reply #90 on: November 15, 2008, 10:25:27 PM »
its worth testing, seeing it doesnt cost you much.
bearsbmw
« Reply #91 on: November 15, 2008, 10:34:36 PM »
Quote from: KyleTaylor;60919
So that tests whether or not an injector is leaking while the engine is off... never really thought about that... my idle issue is prevalent at more than just startup, though.
yes because your fuel system is spose to hold presure untill next startup and and leaky injector would flood the engine causing these symptoms
AcSchnitzer318is
« Reply #92 on: November 15, 2008, 11:36:37 PM »
OK I'll play...
1. ICV (replaced)
2. Vacuum Leaks (did TB heater delete and replaced hoses)
3. o2 Sensor (replaced)
4. Plugs & Wires (replaced as part of maintenance)
5. Fuel Injectors (mustang 19#)
6. Exhaust Header Gasket (had a leak)
7. AFM (replaced)
8. Engine Temp Sensor (replaced)
9. Throttle Position Sensor (replaced)
10. ECU swapped (known good unit)
Also had engine smoke tested (no leaks), fuel pressure tested (40-50psi)... no problems.  I am guessing this problem is completely external to the motor.  Reason for this conclusion is that I swapped in a rebuilt motor (20k miles) that didn't exhibit this behavior in the donor car.  Only after being put into this chassis did it start doing this.  The original motor in this chassis did this as well... so something external to the motor is causing this.  Rules out most sensors, vacuum leaks, or timing.  Any other ideas guys?  I was thinking maybe fuel pump... but fuel pressure tested ok.
roundel318
« Reply #93 on: November 15, 2008, 11:48:03 PM »
good food for thought.....
only thing that comes right to mind is a fuel pressure regulator?
bearsbmw
« Reply #94 on: November 15, 2008, 11:55:22 PM »
yes I would like to see if anybody has done the regulator because I think these can get stuck in the high presure postion and not leak fuel beyond the diafram
I'm going to redo my ground straps tomorow and open my fuel tank and look inside and look at the fuel pump
« Last Edit: November 16, 2008, 12:04:19 AM by bearsbmw »
roundel318
« Reply #95 on: November 16, 2008, 12:02:54 AM »
We need a song "process of elimination".
It could be a fat breaks track :)
bearsbmw
« Reply #96 on: November 16, 2008, 12:07:25 AM »
I love BMW's and all there problems 'Boom De Ah Dah'  'Boom De Ah Dah'  'Boom De Ah Dah'  'Boom De Ah Dah' !!  :D
roundel318
« Reply #97 on: November 16, 2008, 12:08:49 AM »
I am not sure about others, but here is at least one fuel pressure regulator.
Item 6
http://www.realoem.com/bmw/showparts.do?model=AJ93&mospid=47318&btnr=13_0308&hg=13&fg=15
And it seems like it would come and go with an engine swap.
Perhaps there is another on the car somewhere?
bearsbmw
« Reply #98 on: November 16, 2008, 12:15:20 AM »
I remember reading somewhere that the e30 has a check valve at the fuel pump that can fail and cause these symptoms
http://www.m42club.com/forums/showthread.php?t=4688
« Last Edit: November 16, 2008, 12:28:18 AM by bearsbmw »
roundel318
« Reply #99 on: November 16, 2008, 12:20:15 AM »
Good call, dig out the rear seat :)
bearsbmw
« Reply #100 on: November 16, 2008, 12:38:43 AM »
fuel pressure regulator could very well be the problem
roundel318
« Reply #101 on: November 16, 2008, 12:46:52 AM »
A Bentley manual should have some simple test procedure to check it out?
bearsbmw
« Reply #102 on: November 16, 2008, 01:02:07 AM »
No shrader valve on my fuel rail so Im going to remove the regulator and examine it visualy for corosion and rust I will then submerge the regulator in water and put 10psi to it and look for bubbles and then take my sandblasting gun and use the suction hose while under water on the vac nipple and see if the gun picks up water
bearsbmw
« Reply #103 on: November 16, 2008, 09:17:07 AM »
update: removed fuel regulator and there was alot of goldish color residue around the orings... I stuck a small screw driver in the middle hole of the regulator and pushed the spring back and forth and it seemed to be sticking and then started spraying wd40 into the housing and worked the plunger with the very small screw driver up and down and it became alot better ... will let everybody know how car starts on cold start soon
roundel318
ideas
« Reply #104 on: November 16, 2008, 09:58:31 AM »
It's the AN TI CI PA TION
:D
