Author Topic: Cold start engine shakes and sputters  (Read 27403 times)
bearsbmw
« Reply #105 on: November 16, 2008, 10:24:19 AM »
did not solve the problem
roundel318
ideas
« Reply #106 on: November 16, 2008, 11:26:12 AM »
Dang, at least we can put it on the list of things that are checked off.
:rolleyes:
bearsbmw
« Reply #107 on: November 16, 2008, 11:46:05 AM »
I take it back it was fuel presure regulator all the way!!! GOD DAMN !!
Problem is fixed! thank everyone so much for the imput and help
« Last Edit: November 16, 2008, 11:51:30 AM by bearsbmw »
roundel318
ideas
« Reply #108 on: November 16, 2008, 02:15:56 PM »
Nice!
We will have to hit up a few others and have them see if they can replicate the fix!
:D
bearsbmw
« Reply #109 on: November 16, 2008, 03:50:43 PM »
Quote from: roundel318;60975
Nice!
:D
I forgot to reset the ecu after I messed around with the regulator and after I did the reset it was like magic!! I suggest everyone take a look at there's and or replace it
roundel318
« Reply #110 on: November 16, 2008, 05:59:52 PM »
So it was the regulator, you resetting the ECU, or both?
bearsbmw
« Reply #111 on: November 16, 2008, 06:58:56 PM »
both !
AcSchnitzer318is
« Reply #112 on: November 17, 2008, 11:11:27 PM »
How did you get the regulator off the rail?  I was going to replace mine some time ago but gave up after struggling for a half hour or so.  Damnit this could have been fixed months ago.  Oh well at least you found the cultprit in your case.  I hope it fixes mine as well.
I wonder why it only has an effect on initial start?  I'm all excited now...
roundel318
fuel reg
« Reply #113 on: November 17, 2008, 11:45:58 PM »
It was the one back at the tank, not the one on the engine.
KyleTaylor
« Reply #114 on: November 18, 2008, 12:09:55 AM »
So did you do the retro fitted check valve or replace the factory one... which I assume requires a the entire pump...... or what?
roundel318
« Reply #115 on: November 18, 2008, 12:14:38 AM »
Bearsbmw will have to post, I provided the reference car.
Take your back seat out and take a peek.
bearsbmw
« Reply #116 on: November 18, 2008, 12:47:08 AM »
On my car it was the one at the fuel rail but on your e30's it is wise to replace the regulator at the rail and the check valve at the fuel pump under the seat and then reset your ecu...for some reason the ecu would not learn that I fixed the regulator and after the reset it worked like the day I got the car... If my 1995 OEM orginal was sticking I can't imagine what your's is doing
AcSchnitzer318is
« Reply #117 on: November 18, 2008, 07:46:31 PM »
I bet mine is the one at the tank... since it did it post engine swap... oooohhhh the excitement grows....
Anyone have a realoem diagram of that tank regulator?  I haven't looked under that seat in awhile and want to know what to look for.
bearsbmw
« Reply #118 on: November 18, 2008, 07:56:51 PM »
Quote from: AcSchnitzer318is;61174
Photo taken from another thread on this site
JP 91iS
« Reply #119 on: November 18, 2008, 08:06:39 PM »
I can't find one on realoem. :confused:
From the "warm start problems" thread that dark islight posted, it looks like he added a check valve where there was not one previously.
Maybe the E30 fuel pump has a built in mechanism that is supposed to do what the check valve does: retain pressure on the fuel supply lines when the car is off?
EDIT:  ^yeah thats the one I think he added.  I couldn't find a part on realoem with that PN.
-JP
Project M42: generating funds
